Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Issues with asynchronous partitioning on temporary data
Archives de la liste
Chronologique Discussions
  • To: Jérôme Richard <jerome.richard@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Issues with asynchronous partitioning on temporary data
  • Date: Sat, 27 Aug 2016 00:03:11 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:/8BTYBE8MscC6MLIQVGA6p1GYnF86YWxBRYc798ds5kLTJ74p8qwAkXT6L1XgUPTWs2DsrQf2rOQ7/mrATBIoc7Y9itTKNoUD15NoP5VtjRoONSCB0z/IayiRA0BN+MGamVY+WqmO1NeAsf0ag6aiHSz6TkPBke3blItdazLE4Lfx/66y/q1s8WKJV4Z3XzhOPgqcF329VyX7ZhOx9M6a+4Y8VjgmjNwYeNYxGdldxq4vi3XwYOOxqNl6DlaoPk79sRNAu3QdqU8SqFEXnx9azhmrOWijxTITBOO630ASS1W10MQW0mWpC39C7VwqLf/u6JH2SKaNNf6BeQ2VC6l6qotUh7jiC4dOxY49nvWg4p+lvQIjgimoklEyovJbYXdCPp/dKrAec9SEXFIW9tcU2pdAoK2ZpYLE8IAO/xZps/zvQ1d/lOFGQCwCba3mXdzjXjs0Ph/irx5HA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Jérôme Richard, on Fri 26 Aug 2016 18:24:35 +0200, wrote:
> So, I would like to asynchronously call starpu_data_partition_clean by
> calling a function like starpu_data_partition_clean_submit, but this
> function doesn't seem to exist. Is starpu_data_partition_clean already
> asynchronous?
It is not already asynchronous.
> Else, is it possible to do this with StarPU?
Not yet, but it should be easy to add and backport to the 1.2 branch.
> 2. StarPU reports the following error: The data for the handle
> 0x2248430 is requested, but the handle does not have a valid value.
That's odd. From your description you seem to be using it right.
> I can send a simple example where I encounter the error message.
That's help understand what is going wrong.
Samuel
Haut de le page
