Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] help with trace.rec and tasks.rec
Archives de la liste
Chronologique Discussions
  • To: Alfredo Buttari <alfredo.buttari@enseeiht.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] help with trace.rec and tasks.rec
  • Date: Tue, 6 Sep 2016 14:22:30 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 09/06/2016 02:16 PM, Alfredo Buttari wrote:
Samuel,
thanks for the quick answer. See below
On Tue, Sep 6, 2016 at 2:03 PM, Samuel Pitoiset
<samuel.pitoiset@inria.fr <mailto:samuel.pitoiset@inria.fr>> wrote:
Weird. I have just tried locally and the output for me looks like:
$ python2.7 tools/starpu_trace_state_stats.py trace.rec | column -t
-s ","
"Name" "Count" "Type" "Duration"
"Initializing" 4 "Runtime" 1.036028
"Overhead" 4540 "Runtime" 5.291885
"Idle" 1516 "Other" 0.60503
"Scheduling" 3026 "Runtime" 1.346616
"Sleeping" 30 "Other" 88.045689
"FetchingInput" 1512 "Runtime" 0.961838
"chol_model_21" 212 "Task" 100.915113 ---> This is what
you want!
"PushingOutput" 1512 "Runtime" 0.587924
"chol_model_22" 1276 "Task" 890.891958
"chol_model_11" 24 "Task" 3.280441
"Submitting task" 1512 "User" 1.506503
This is with starpu-svn from today or yesterday.
Which version are you using?
I am using the latest revision of the trunk. Is there any configure
option or (at runtime) any environment variable I have to set?
I used:
STARPU_GENERATE_TRACE=1 examples/cholesky/cholesky_grain_tag -size 2048
Mmmh, you might need to build StarPU with Fxt (cf. --with-fxt=<dir>) because trace.rec is quite related to paje.trace actually (a bunch of similar code are shared).
Is there a paje.trace generated after the execution?
I don't remember how to parse the tasks.rec, maybe there is a tool
in trunk/tools, not sure though.
The main difference between tasks.rec and trace.rec is that the
former contains more information about the tasks and the latter only
contains the different states of the execution.
thanks for the details.
Alfredo Buttari, PhD
CNRS-IRIT
2 rue Camichel, 31071 Toulouse, France
http://buttari.perso.enseeiht.fr
Haut de le page
