Archives de la liste
- From: Alfredo Buttari <alfredo.buttari@enseeiht.fr>
- To: Samuel Pitoiset <samuel.pitoiset@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] help with trace.rec and tasks.rec
- Date: Tue, 6 Sep 2016 15:50:29 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=alfredo.buttari@gmail.com; spf=Pass smtp.mailfrom=alfredo.buttari@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f48.google.com
- Ironport-phdr: 9a23:Oz5DDhRgkk+Wa9Imwlv2hKO5Fdpsv+yvbD5Q0YIujvd0So/mwa65ZRWN2/xhgRfzUJnB7Loc0qyN4vmmBD1Lvs7J8ChbNscdD1ld0YRetjdjKfbNMVf8Iv/uYn5yN+V5f3ghwUuGN1NIEt31fVzYry76xzcTHhLiKVg9fbytScbshsi6n9q/54fUK10RwmHsOPUvfV7p9U2R7pBQ2to6bP5pi1PgmThhQ6xu32RmJFaezV7Xx/yb29pdyRlWoO8r7MVaUK/3LOwSRL1cCyk6YShuvJW4/TGKdwaE52MdX2MKiVIIRlGdtFCpFqv25xDzs/dw3GGiPNHxTKs5RXz29K5uVRLszj8GKzk462zLos12lqNS5hy78U9R2YnRNaiROuBzcqSVV84GWWNbX44FXihPGI6waM0FEvYdNPxZh4T7vFYDrBuiQwe2UrC8ggRUj2P7iPVpm98qFhvLiUl5R4oD
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
I have managed to make it work. I think I have found the problem. When installing though spack, the --enable-paje-codelet-details is added to the configure line which results in no Task events in the tasks.rec file. Do you confirm this is the case?
On Tue, Sep 6, 2016 at 2:33 PM, Samuel Pitoiset <samuel.pitoiset@inria.fr> wrote:
Please update your repo. The following commit should help. :)
commit be211beddfa10db55d829cca70f7084692b8763f
Author: spitoiset <spitoiset@176f6dd6-97d6-42f4-bd05-d3db9ad07c7a>
Date: Tue Sep 6 12:32:39 2016 +0000
debug/traces: always dump codelet details to trace.rec
When no paje.trace file is generated, codelet details (ie. Task states)
were not dumped to trace.rec. This has been reported by Alfredo Buttari.
On 09/06/2016 02:22 PM, Samuel Pitoiset wrote:
Alfredo Buttari, PhD
CNRS-IRIT
2 rue Camichel, 31071 Toulouse, France
http://buttari.perso.enseeiht.fr
CNRS-IRIT
- [Starpu-devel] help with trace.rec and tasks.rec, Alfredo Buttari, 06/09/2016
- Re: [Starpu-devel] help with trace.rec and tasks.rec, Samuel Pitoiset, 06/09/2016
- Re: [Starpu-devel] help with trace.rec and tasks.rec, Alfredo Buttari, 06/09/2016
