Archives de la liste
Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock
Chronologique Discussions
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Adam Larat <adam.larat@ecp.fr>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock
- Date: Fri, 23 Sep 2016 12:45:40 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
The bug has been fixed in the SVN trunk
and 1.2 branch. Thanks for the report.
Bonjour,
Nathalie On 23/09/2016 10:41, Adam Larat wrote: je cherche à compiler StarPU (tiré depuis le dépôt SVN) avec l'option -enable-fxt-lock. Le configure se passe bien ../configure --prefix=/home/alarat/StarPU/StarPU-FXT/Install --enable-mpi-check --with-fxt --enable-fxt-lock --enable-openmp mais la compile génère une erreur In file included from ../../src/common/fxt.h:212:0, from ../../src/common/starpu_spinlock.h:23, from ../../src/common/starpu_spinlock.c:18: ../../src/common/starpu_spinlock.h: In function '__starpu_spin_lock': ../../src/common/fxt.h:809:62: error: too many arguments to function '_starpu_gettid' _STARPU_FUT_DO_PROBE2STR(_STARPU_FUT_LOCKING_SPINLOCK,line,_starpu_gettid(file, line),file); \ ^ Le log est en PJ. Quel est le problème ? Merci pour votre aide, Adam _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Adam Larat, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Nathalie Furmento, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Adam Larat, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Samuel Thibault, 28/09/2016
