Archives de la liste
Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock
Chronologique Discussions
- To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock
- Date: Fri, 23 Sep 2016 14:00:12 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=adam.larat@ecp.fr; spf=Pass smtp.mailfrom=adam.larat@ecp.fr; spf=None smtp.helo=postmaster@smtp3.ecp.fr
- Ironport-phdr: 9a23:e0jBvh/nqlV4ov9uRHKM819IXTAuvvDOBiVQ1KB92+scTK2v8tzYMVDF4r011RmSDN+ds60P17SempujcFRI2YyGvnEGfc4EfD4+ouJSoTYdBtWYA1bwNv/gYn9yNs1DUFh44yPzahANS47AblHf6ke/8SQVUk2mc1EkfKKtRcWO0Yye7KObw9XreQJGhT6wM/tZDS6dikHvjPQQmpZoMa0ryxHE8TNicuVSwn50dxrIx06vrpT4wJk2uT9Msug56otMXLv3e4w8TKdEF3IpPWcv68CttB/ZTALJ6GFWGjENjhNSGxWA4BzkU5PZtirhqvE71yedJ8L7C7EyQzWrqalxHkzGkiACYhc1+WSfrsVqhb4T9Butrhk5x4fOaZ29OfFmOK3HK4BJDVFdV9pcAnQSSri3aJECWrIM
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Great, it's working! Thank you! Now I have another problem with the prof_file when I want to plot the starpu_fxt_data_trace. If I use the SVN trunk version, the data trace (attached) has only one codelet : 'unknown'. However I know that the tasks have their correct names because the Gantt diagram generated with starpu_fxt_tools contains them. The corresponding prof_file is here : http://perso.ecp.fr/~larata/prof_file_alarat_0 Adam PS: Since this is another question, do you prefer I open a new thread? Le 09/23/2016 à 12:45 PM, Nathalie
Furmento a écrit :
The bug has been fixed in the SVN
trunk and 1.2 branch. Thanks for the report.
Bonjour, Nathalie On 23/09/2016 10:41, Adam Larat wrote: je cherche à compiler StarPU (tiré depuis le dépôt SVN) avec l'option -enable-fxt-lock. Le configure se passe bien ../configure --prefix=/home/alarat/StarPU/StarPU-FXT/Install --enable-mpi-check --with-fxt --enable-fxt-lock --enable-openmp mais la compile génère une erreur In file included from ../../src/common/fxt.h:212:0, from ../../src/common/starpu_spinlock.h:23, from ../../src/common/starpu_spinlock.c:18: ../../src/common/starpu_spinlock.h: In function '__starpu_spin_lock': ../../src/common/fxt.h:809:62: error: too many arguments to function '_starpu_gettid' _STARPU_FUT_DO_PROBE2STR(_STARPU_FUT_LOCKING_SPINLOCK,line,_starpu_gettid(file, line),file); \ ^ Le log est en PJ. Quel est le problème ? Merci pour votre aide, Adam _______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
-- Adam LARAT Chargé de Recherche CNRS Laboratoire EM2C - UPR288 - École Centrale Paris Grande Voie des Vignes 92295 Châtenay-Malabry Cedex France Tél.: 0033 141 131 057 |
- [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Adam Larat, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Nathalie Furmento, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Adam Larat, 23/09/2016
- Re: [Starpu-devel] Compilation de la version SVN avec l'option --enable-fxt-lock, Samuel Thibault, 28/09/2016
