Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] startpu 1.2.0 compilation issues
- Date: Fri, 18 Nov 2016 12:11:29 -0500
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jagode@icl.utk.edu; spf=None smtp.mailfrom=jagode@icl.utk.edu; spf=None smtp.helo=postmaster@mail-it0-f42.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
I configured StarPU 1.2.0 as follows (see config.log attached):./configure --prefix=$PWD/install --disable-build-doc --disable-cuda --disable-opencl CC=icc FC=ifort F77=ifort MPICC=mpiicc CXX=icpc
During compilation, I get the following error:
Error: Assumed-shape array 'arglist' at (1) cannot be an argument to the procedure 'fstarpu_task_insert' at (2) because the procedure is BIND(C)
../../include/fstarpu_mod.f90:1444.63-45:
subroutine fstarpu_unpack_arg(cl_arg,bufferlist) bind(C)
2 1
Error: Assumed-shape array 'bufferlist' at (1) cannot be an argument to the procedure 'fstarpu_unpack_arg' at (2) because the procedure is BIND(C)
../../include/fstarpu_mod.f90:330.16:
function fstarpu_worker_get_by_devid(typeid, devid) bind(C)
1
___________________________________
Heike Jagode
Innovative Computing Laboratory (ICL)
University of Tennessee, Knoxville (UTK)
e-mail: jagode@icl.utk.edu
phone: +1 865 974 8057
fax: +1 865 974 8296
Heike Jagode
config.log
Description: Binary data
- [Starpu-devel] startpu 1.2.0 compilation issues, Heike Jagode, 18/11/2016
- [Starpu-devel] Fwd: startpu 1.2.0 compilation issues, Heike Jagode, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Nathalie Furmento, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Heike Jagode, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Olivier Aumage, 23/11/2016
