Archives de la liste
- To: starpu-devel@lists.gforge.inria.fr, Mathieu Faverge <mathieu.faverge@inria.fr>
- Subject: [Starpu-devel] Fwd: startpu 1.2.0 compilation issues
- Date: Tue, 22 Nov 2016 17:22:57 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jagode@icl.utk.edu; spf=None smtp.mailfrom=jagode@icl.utk.edu; spf=None smtp.helo=postmaster@mail-io0-f178.google.com
- Ironport-phdr: 9a23:+GPEXRJV4HGpvW/iC9mcpTZWNBhigK39O0sv0rFitYgUL//xwZ3uMQTl6Ol3ixeRBMOAuqkC0bed6v2/ESxYuNDa7yBEKMQNHzY+yuwo3CUYSPafDkP6KPO4JwcbJ+9lEGFfwnegLEJOE9z/bVCB6le77DoVBwmtfVEtfre9Msfogs+2z+G//YHIK0UN3WLlIOA6EBLjthnYrNELxIdvNKs14h/IuWdTPetYwnlnKBSSmQz974G+5tor1i1Mu/Ms6oZuWLv3Zas1BehdBSgmMm0oosPiqxTZQgan530GU2xQnAAeUCbf6xSvfprwsSaylONy3yWXdZn0RL8zVTmK7qxvDgL0i2EKOyNvozKfsdB5kK8O+EHpnBd42YOBJdjNbPc=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Re-sending this email since it's still a pending issues and I haven't heard back yet:
Thanks for any help!---------- Forwarded message ----------
Date: Fri, Nov 18, 2016 at 12:11 PM
Subject: startpu 1.2.0 compilation issues
./configure --prefix=$PWD/install --disable-build-doc --disable-cuda --disable-opencl CC=icc FC=ifort F77=ifort MPICC=mpiicc CXX=icpc
During compilation, I get the following error:
Error: Assumed-shape array 'arglist' at (1) cannot be an argument to the procedure 'fstarpu_task_insert' at (2) because the procedure is BIND(C)
../../include/fstarpu_mod.f90:1444.63-45:
subroutine fstarpu_unpack_arg(cl_arg,bufferlist) bind(C)
2 1
Error: Assumed-shape array 'bufferlist' at (1) cannot be an argument to the procedure 'fstarpu_unpack_arg' at (2) because the procedure is BIND(C)
../../include/fstarpu_mod.f90:330.16:
function fstarpu_worker_get_by_devid(typeid, devid) bind(C)
1
Any suggested what I could be doing wrong?
Thanks,
Heike
Hi,
I configured StarPU 1.2.0 as follows (see config.log attached):./configure --prefix=$PWD/install --disable-build-doc --disable-cuda --disable-opencl CC=icc FC=ifort F77=ifort MPICC=mpiicc CXX=icpc
2 1
1
___________________________________
Heike Jagode
Innovative Computing Laboratory (ICL)
University of Tennessee, Knoxville (UTK)
e-mail: jagode@icl.utk.edu
phone: +1 865 974 8057
fax: +1 865 974 8296
Heike Jagode
config.log
Description: Binary data
- [Starpu-devel] startpu 1.2.0 compilation issues, Heike Jagode, 18/11/2016
- [Starpu-devel] Fwd: startpu 1.2.0 compilation issues, Heike Jagode, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Nathalie Furmento, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Heike Jagode, 22/11/2016
- Re: [Starpu-devel] startpu 1.2.0 compilation issues, Olivier Aumage, 23/11/2016
