Archives de la liste
- To: Luka Stanisic <luka.stanisic@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation
- Date: Tue, 13 Dec 2016 14:34:17 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23:h1y4PxCedddVuYbWFv17UyQJP3N1i/DPJgcQr6AfoPdwSP74pMbcNUDSrc9gkEXOFd2CrakV0KyI7+u6ACRAuc/H6y9SNsQUFlcssoY/oU8JOIa9E0r1LfrnPWQRPf9pcxtbxUy9KlVfA83kZlff8TWY5D8WHQjjZ0IufrymUqabtcm81viz9pvPeE0IwWPlOfIhGi6rth3cvdU6ho5rK6B5ikeY4ygAR+MD4X5rLBqogx/659yx99Y39zlTsrQ668dGUL77dIw5S6ZZBXIoKTZmytfssEzmTBGM4TM5Q2ESgxlPGAvEpEX/X43ytS7SvfE7xSyHe9b7G+NnEQ++5rtmHUe7wBwMMCQ0pSSK08E=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Luka,
and thank you for your reply.
I performed the same experiment twice, once with the size_base field included and once without it. I erased the samples directory before each experiment and gave it a few rounds to calibrate properly (STARPU_CALIBRATE=1). Here are the corresponding sample folders:
https://dl.dropboxusercontent.com/u/1521774/sampling_with_size_base.tar.gz
https://dl.dropboxusercontent.com/u/1521774/sampling_without_size_base.tar.gz
In this case, the error seems to be about 35%.
As I mentioned in my previous email, the code is shared memory only (at the moment). I performed the experiment on my local machine (quad-core i5) but my plan is to move on to a bigger machine (28 or 42 cores per node) and distributed memory once everything works.
I don't quite understand why SimGrid would include any fetching time to the simulation since everything is running in shared memory.
Best Regards,
Mirko
On 2016-12-12 18:21, Luka Stanisic wrote:
Hello Mirko,
Indeed, 50% prediction error is quite big and it suggests that
something is probably not correctly configured. Could you please send
us a compressed version of you ".starpu/sampling" folder, the one from
which simulation will read the performance models. This can help us
get the first ideas of the machine and application you are trying to
simulate.
To answer your question, the fetching time is computed based on the
size of the data being transfered, latency and bandwidth of the link
(in machine.platform.xml file) and the possible contention due to
other transfers occurring in parallel.
Best regards,
Luka
On 07/12/2016 12:50, Mirko Myllykoski wrote:
Hi,
my name is Mirko Myllykoski and I work as a PostDoc researcher for the NLAFET project at Umeå University.
I am currently implementing a (shared memory) numerical software using StarPU and I am trying to simulate my code using SimGrid. However, I noticed that the simulated execution time is way off (about 50%). I checked the generated FxT traces using vite and it seems that SimGrid introduces too much fetching time (State: FetchingInput) to the simulation.
How is this fetching time being computed? My performance models include the starpu_perfmodel::size_base data field and I guess that information is somehow used to compute the fetch time.
Best Regards,
Mirko Myllykoski
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
http://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Mirko Myllykoski, 07/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Luka Stanisic, 12/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Mirko Myllykoski, 13/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Luka Stanisic, 13/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Mirko Myllykoski, 14/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Luka Stanisic, 14/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Mirko Myllykoski, 16/12/2016
- Re: [Starpu-devel] StarPU+SimGrid: FetchingInput computation, Luka Stanisic, 16/12/2016
