Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] StarPU+SimGrid: FetchingInput computation
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] StarPU+SimGrid: FetchingInput computation
  • Date: Wed, 07 Dec 2016 12:50:03 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi,
my name is Mirko Myllykoski and I work as a PostDoc researcher for the NLAFET project at Umeå University.
I am currently implementing a (shared memory) numerical software using StarPU and I am trying to simulate my code using SimGrid. However, I noticed that the simulated execution time is way off (about 50%). I checked the generated FxT traces using vite and it seems that SimGrid introduces too much fetching time (State: FetchingInput) to the simulation.
How is this fetching time being computed? My performance models include the starpu_perfmodel::size_base data field and I guess that information is somehow used to compute the fetch time.
Best Regards,
Mirko Myllykoski
Haut de le page
