Archives de la liste
- To: Xavier Teruel <xavier.teruel@bsc.es>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc)
- Date: Wed, 11 Jan 2017 18:19:33 +0100
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
Xavier Teruel, on Wed 11 Jan 2017 15:45:33 +0100, wrote:
> /usr/local/cuda/include/host_config.h(79): error: #error directive: --
> unsupported ICC configuration! Only ICC 15.0 on Linux x86_64 is supported!
> #error -- unsupported ICC configuration! Only ICC 15.0 on Linux x86_64 is
> supported!
Unfortunately that's a limitation of your CUDA version.
> ../../../../../sources/starpu-1.2.0/include/fstarpu_mod.f90(1435): error
> #8520: An array dummy argument of a BIND(C) procedure must be an explicit
> shape or assumed size array. [ARGLIST]
> subroutine fstarpu_task_insert(arglist) bind(C)
> Is that a known issue? Could you provide some help?
IIRC we have already seen this issue with some fortran compilers, yes.
You can pass --disable-fortran to ./configure to just avoid the issue.
Samuel
- [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Xavier Teruel, 11/01/2017
- Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Samuel Thibault, 11/01/2017
- Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Xavier Teruel, 12/01/2017
