Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc)
- Date: Thu, 12 Jan 2017 10:26:17 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=xavier.teruel@bsc.es; spf=Pass smtp.mailfrom=xavier.teruel@bsc.es; spf=None smtp.helo=postmaster@opsmail01.bsc.es
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Samuel, Olivier,
thanks for your help, finally I succeded in installing it :-)
Best regards,
Xavier Teruel-García
El 11/01/2017 a las 18:19, Samuel Thibault escribió:
Hello,
Xavier Teruel, on Wed 11 Jan 2017 15:45:33 +0100, wrote:
/usr/local/cuda/include/host_config.h(79): error: #error directive: --Unfortunately that's a limitation of your CUDA version.
unsupported ICC configuration! Only ICC 15.0 on Linux x86_64 is supported!
#error -- unsupported ICC configuration! Only ICC 15.0 on Linux x86_64 is
supported!
../../../../../sources/starpu-1.2.0/include/fstarpu_mod.f90(1435): errorIIRC we have already seen this issue with some fortran compilers, yes.
#8520: An array dummy argument of a BIND(C) procedure must be an explicit
shape or assumed size array. [ARGLIST]
subroutine fstarpu_task_insert(arglist) bind(C)
Is that a known issue? Could you provide some help?
You can pass --disable-fortran to ./configure to just avoid the issue.
Samuel
WARNING / LEGAL TEXT: This message is intended only for the use of the
individual or entity to which it is addressed and may contain
information which is privileged, confidential, proprietary, or exempt
from disclosure under applicable law. If you are not the intended
recipient or the person responsible for delivering the message to the
intended recipient, you are strictly prohibited from disclosing,
distributing, copying, or in any way using this message. If you have
received this communication in error, please notify the sender and
destroy and delete any copies you may have received.
http://www.bsc.es/disclaimer
- [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Xavier Teruel, 11/01/2017
- Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Samuel Thibault, 11/01/2017
- Re: [Starpu-devel] Installing StarPU 1.2.0 (problems with icc), Xavier Teruel, 12/01/2017
