Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Thomas Lambert <thomas.lambert@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Problème mode Redux de StarPU
- Date: Thu, 20 Apr 2017 10:21:27 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Merci de préciser quelle version de
StarPU est utilisée, et il manque le code. Vu la backtrace, la
fonction starpu_codelet_unpack_args est appelée mais je ne le vois
pas dans le code fourni.
Merci, Nathalie On 20/04/2017 10:14, Thomas Lambert wrote: Bonjour,
Je suis en train de travailler avec la bibliothèque StarPU
et je rencontre un problème que je n'arrive pas à résoudre.
En gros je travaille avec des matrices par bloc dont l'une
est utilisée en mode STARPU_REDUX par mes tâches. J'ai pris
modèle sur ce qui est fait dans "pi_redux.c" mais
malheureusement ça ne fonctionne pas. Si je n'exclus pas
l'erreur bête (je ne suis pas un grand habitué du C), avoir
votre avis m'aidera peut-être à trouver plus facilement
l'erreur.
Je vous donne en pièce jointe mon code (l'erreur est
seulement dans le main, le reste est là pour que vous puissiez
tester si besoin). Je détaille juste en dessous les parties
probablement les plus pertinentes au vu du problème.
Pour être plus précis j'ai l'impression que l'erreur
apparait à la fin du programme lors de la tentative de
libération du handle placé en mode redux. Je reçois alors le
message suivant :
/usr/local/lib/libstarpu-1.2.so.4(starpu_codelet_unpack_args+0xe5)[0x7f31c72697d5]
./test[0x408b6d] /usr/local/lib/libstarpu-1.2.so.4(_starpu_push_task_to_workers+0x13a)[0x7f31c723cbea] /usr/local/lib/libstarpu-1.2.so.4(_starpu_repush_task+0x6b)[0x7f31c723d16b] /usr/local/lib/libstarpu-1.2.so.4(_starpu_enforce_deps_and_schedule+0x95)[0x7f31c721dfa5] /usr/local/lib/libstarpu-1.2.so.4(_starpu_submit_job+0xbd)[0x7f31c721efed] /usr/local/lib/libstarpu-1.2.so.4(starpu_task_submit+0x1c1)[0x7f31c7220d21] /usr/local/lib/libstarpu-1.2.so.4(_starpu_data_end_reduction_mode+0x61a)[0x7f31c72615ba] /usr/local/lib/libstarpu-1.2.so.4(+0x2fd17)[0x7f31c722dd17] /usr/local/lib/libstarpu-1.2.so.4(_starpu_attempt_to_submit_data_request_from_apps+0x3d)[0x7f31c722df5d] /usr/local/lib/libstarpu-1.2.so.4(+0x654df)[0x7f31c72634df] /usr/local/lib/libstarpu-1.2.so.4(starpu_data_unregister+0x36)[0x7f31c7264356] ./test[0x40ad1a] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xf5)[0x7f31c6e5af45] ./test[0x401769] test: util/starpu_task_insert.c:42: starpu_codelet_unpack_args: Assertion `cl_arg' failed. Abandon (core dumped) Pour ce qui est du code lui même je définis mon codelet
d'initialisation comme suit (l 148):
void init_cpu_func(void *descr[], void *cl_arg)
{ int *val = (int *)STARPU_VARIABLE_GET_PTR(descr[0]); *val = 0; } { .cpu_funcs = {init_cpu_func}, .cpu_funcs_name = {"init_cpu_func"}, .modes = {STARPU_W}, .nbuffers = 1 }; mon codelet de réduction comme cela (l 162):
void redux_cpu_func(void *descr[], void *cl_arg)
{ int *a = (int *)STARPU_VARIABLE_GET_PTR(descr[0]); int *b = (int *)STARPU_VARIABLE_GET_PTR(descr[1]); *a = *a + *b; } static struct starpu_codelet redux_codelet = { .cpu_funcs = {redux_cpu_func}, .cpu_funcs_name = {"redux_cpu_func"}, .modes = {STARPU_RW, STARPU_R}, .nbuffers = 2 }; mes handles (l236):
starpu_data_handle_t *C_handle ;
C_handle = malloc((N/l)*(N/l)*sizeof(starpu_data_handle_t)) ; for(i=0;i<N/l;i++){ for (j =0;j<N/l;j++){ starpu_vector_data_register(&GET2(C_handle,i,j,N/l),STARPU_MAIN_RAM, (uintptr_t)(GET2(C_block,i,j,N/l)),l*l,sizeof(int)) ; starpu_data_set_reduction_methods(GET2(C_handle,i,j,N/l),&redux_codelet,&init_codelet) ; } ; } ; et je les libère comme suit (l 323):
for(i=0;i<N/l;i++){
int j ; for(j=0;j<N/l;j++){ starpu_data_unregister(GET2(C_handle,i,j,N/l)) ; } ; } ; Voilà, j'espère que vous pourrez m'aider. Si c'est plus
commode pour vous je suis sur Bordeaux et peut me déplacer
jusqu'à votre bureau.
Bonne journée
Thomas Lambert
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Problème mode Redux de StarPU, Thomas Lambert, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Nathalie Furmento, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Thomas Lambert, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Samuel Thibault, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Samuel Thibault, 28/04/2017
