Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Problème mode Redux de StarPU
Archives de la liste
Chronologique Discussions
  • To: Thomas Lambert <thomas.lambert@inria.fr>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Problème mode Redux de StarPU
  • Date: Thu, 20 Apr 2017 10:22:10 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Thomas Lambert, on jeu. 20 avril 2017 10:14:46 +0200, wrote:
> /usr/local/lib/libstarpu-1.2.so.4(starpu_codelet_unpack_args+0xe5)
> [0x7f31c72697d5]
> ./test[0x408b6d]
Il faudrait compiler ton test avec -g pour avoir plus d'info sur qui
appelle ici starpu_codelet_unpack_args dans ton programme.
> Pour ce qui est du code lui même je définis mon codelet d'initialisation
> comme
> suit (l 148):
Ce code en lui-même est complètement raisonnable, et ne fait pas appel à
starpu_codelet_unpack_args. Le problème est donc a priori ailleurs...
Samuel
Haut de le page
