Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Cc: starpu-devel@lists.gforge.inria.fr, Thomas Lambert <thomas.lambert@inria.fr>
- Subject: Re: [Starpu-devel] Problème mode Redux de StarPU
- Date: Thu, 20 Apr 2017 10:54:17 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Nathalie Furmento, on jeu. 20 avril 2017 10:46:02 +0200, wrote:
> Je ne suis pas sûre qu'appeler la fonction starpu_codelet_unpack_args en
> dehors de la fonction d'execution d'une codelet fonctionne.
Ce n'est pas prévu pour en tous cas :) Il se trouve que ça fonctionne
parce qu'elle ne fait que lire dans la tâche, et que dans que
l'ordonnanceur n'a pas relâché la tâche, elle existe.
Samuel
- Re: [Starpu-devel] Problème mode Redux de StarPU, (suite)
- Re: [Starpu-devel] Problème mode Redux de StarPU, Thomas Lambert, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Samuel Thibault, 20/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Samuel Thibault, 28/04/2017
- Re: [Starpu-devel] Problème mode Redux de StarPU, Nathalie Furmento, 20/04/2017
