Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Debugging starPU application with gdb
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Huy Duc Doan <huydoan@utexas.edu>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Debugging starPU application with gdb
  • Date: Thu, 11 May 2017 11:49:59 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello Huy,
I do not think we can really do much to help you here. There is nothing specific in StarPU to allow applications debugging (except for --enable-debug).
I would advise you to contact the technical support of the supercomputer to get some help.
Regards,
Nathalie
On 06/05/2017 21:00, Huy Duc Doan wrote:
I'm trying to debug my starPU application. I built starPU with --enable-debug flag and when I built my application with clang++, I also used the -g or -ggdb flags. I was able to debug on my local machine, i.e. stopping at breakpoints and examining the memory. However, I cannot debug the program in the same way when I ran gdb on a node of the supercomputer I have access to. On my local machine, it was reported that the libthread_debug was used to debug. I did not get that message on the supercomputer and thus I could not debug. I verified that the libthread_debug was in /libs/ on the supercomputer.
Please give me some insights.
Best,
Huy Doan
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Haut de le page
