Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Executing Cholesky with StarPU
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: [Starpu-devel] Executing Cholesky with StarPU
  • Date: Thu, 11 May 2017 01:19:11 +0300
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=geomat88@gmail.com; spf=Pass smtp.mailfrom=geomat88@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f50.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear sir/madam,
Hello. I have installed the StarPU framework and I would like to execute the distributed cholesky version. However I am little bit confused with the command line arguments.
Actually, I would like to get strong scalability results, i.e. increase the number of nodes while the matrix size is the same.
So lets say that for the single node implementation the -size=8192 and the -nblocks=64, i.e. Matrix Size=8192x8192 and Tile Size=128x128
How should I configure the size and nblocks flags to have the same matrix size for 2 nodes and 4 nodes?
Thank you very much,
George Matheou
Haut de le page
