Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Executing Cholesky with StarPU
Archives de la liste
Chronologique Discussions
  • To: giorgos matheou <geomat88@gmail.com>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Executing Cholesky with StarPU
  • Date: Thu, 11 May 2017 14:15:37 +0200
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
giorgos matheou, on jeu. 11 mai 2017 15:00:44 +0300, wrote:
> Well I need the Cholesky benchmarks for comparison purposes. So it is OK
> since
> other frameworks have the same implementation.
Perhaps there is a misunderstanding: I'm saying that the implementation
shipped within StarPU may not be a so good StarPU implementation, while
Chameleon does provide a well-benchmarked StarPU implementation.
> The execution terminates with the following error:
> [n081:29365] too many retries sending message to 0x0075:0x00030d11, giving
> up
> [n082:25251] too many retries sending message to 0x0075:0x00030d11, giving
> up
This looks like an issue in the MPI implementation.
> Also, I am receiving these warnings:
> [starpu][check_bus_config_file] No performance model for the bus,
> calibrating...
> [starpu][check_bus_config_file] ... done
That is expected: the first time you run StarPU it checks the machine.
> For each node:
> [starpu][_starpu_mpi_print_thread_level_support] MPI_Init_thread level =
> MPI_THREAD_SERIALIZED; Multiple threads may make MPI calls, but only one at
> a
> time.
That is just informational actually, we have just removed it.
> For the execution I use these commands:
> export STARPU_CALIBRATE=1
> STARPU_SCHED=dmdas mpirun --npernode 1 ./starpu-1.1.7/mpi/examples/
> matrix_decomposition/mpi_cholesky_distributed -size $MATRIX_SIZE -nblocks $
> ((MATRIX_SIZE/BLOCK_SIZE))
That should be fine.
I however notice that you are using starpu 1.1.7. The 1.1 branch is
very old, you should really used starpu 1.2.2 which has just been
released.
Samuel
Haut de le page
