Archives de la liste
- To: Kadir Akbudak <kadir.akbudak@kaust.edu.sa>
- Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Different nodes are owning W data
- Date: Tue, 20 Jun 2017 13:52:55 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
Kadir Akbudak, on mar. 20 juin 2017 11:25:45 +0300, wrote:
> [3][starpu_mpi][_starpu_mpi_task_decode_v:412] Different nodes are
> owning W data. The node to execute the codelet is going to be selected
> with the current selection node policy. See
> starpu_mpi_node_selection_set_current_policy() to change the policy,
> or use STARPU_EXECUTE_ON_NODE or STARPU_EXECUTE_ON_DATA to specify the
> node
Mmm, this warning is probably overzealous indeed, notably since it
doesn't seem to be overridable. Nathalie, we should probably not emit
the warning when starpu_mpi_node_selection_set_current_policy was
called?
Samuel
- [Starpu-devel] Different nodes are owning W data, Kadir Akbudak, 20/06/2017
- Re: [Starpu-devel] Different nodes are owning W data, Samuel Thibault, 20/06/2017
- Re: [Starpu-devel] Different nodes are owning W data, Nathalie Furmento, 21/06/2017
- <Suite(s) possible(s)>
