Archives de la liste
- From: Nathalie Furmento <nathalie.furmento@labri.fr>
- To: Samuel Thibault <samuel.thibault@inria.fr>, Kadir Akbudak <kadir.akbudak@kaust.edu.sa>, starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Different nodes are owning W data
- Date: Wed, 21 Jun 2017 10:08:27 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello,
The message was a leftover from some debugging sessions. I changed the
code so it will only be displayed in debug mode.
Cheers,
Nathalie
On 20/06/2017 13:52, Samuel Thibault wrote:
> Hello,
> Kadir Akbudak, on mar. 20 juin 2017 11:25:45 +0300, wrote:
>> [3][starpu_mpi][_starpu_mpi_task_decode_v:412] Different nodes are
>> owning W data. The node to execute the codelet is going to be selected
>> with the current selection node policy. See
>> starpu_mpi_node_selection_set_current_policy() to change the policy,
>> or use STARPU_EXECUTE_ON_NODE or STARPU_EXECUTE_ON_DATA to specify the
>> node
> Mmm, this warning is probably overzealous indeed, notably since it
> doesn't seem to be overridable. Nathalie, we should probably not emit
> the warning when starpu_mpi_node_selection_set_current_policy was
> called?
> Samuel
> _______________________________________________
> Starpu-devel mailing list
> Starpu-devel@lists.gforge.inria.fr
> https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
- [Starpu-devel] Different nodes are owning W data, Kadir Akbudak, 20/06/2017
- Re: [Starpu-devel] Different nodes are owning W data, Samuel Thibault, 20/06/2017
- Re: [Starpu-devel] Different nodes are owning W data, Nathalie Furmento, 21/06/2017
- <Suite(s) possible(s)>
