Archives de la liste
- To: <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU on IBM Power8 systems
- Date: Tue, 20 Jun 2017 15:10:32 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=vedran.novakovic@stfc.ac.uk; spf=None smtp.mailfrom=vedran.novakovic@stfc.ac.uk; spf=None smtp.helo=postmaster@smtp-out6.electric.net
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Samuel,
Good news:
StarPU (SVN version 21567) indeed builds on Power8LE, with CUDA support.
Configured as:
NVCC_CC=`which xlC_r` NVCC="`which nvcc` -arch sm_60" ./configure
--prefix=... --enable-dependency-tracking --disable-mpi --enable-long-check
--disable-valgrind --enable-maxcudadev=4 --disable-opencl
--disable-fstack-protector-all --enable-verbose=extra --enable-model-debug
--enable-memory-stats --disable-glpk --disable-ayudame1 --disable-ayudame2
--enable-openmp --disable-build-examples --enable-blas-lib=none
--disable-starpufft --disable-build-doc --with-gnu-ld --with-cuda-dir=...
--without-x
with IBM XL C 13.1.5, Fortran 15.1.5, and CUDA 8.0.
Bad news (but not really bad at all):
Unless some debugging flags that XL compilers don't understand are removed,
as with:
find . -name 'Makefile' -exec sed -i -e 's/\-gdwarf\-2//g' -e 's/\-g3/-g/g'
(i.e., -gdwarf-2 -g3 to -g)
they fail with
xlc_r: error: 1501-230 Internal compiler error...
With such change the build completes successfully.
Running `make check` gives me these failures so far, for your information (it
takes a long time to run):
FAIL: datawizard/variable_size
>From variable_size.log:
[starpu][17592869712080][_starpu_create_request_to_fetch_data:datawizard/coherency.c@546]
<-- (data available)
[starpu][starpu_memchunk_tidy] Low memory left on node RAM 0 (-2MiB over
1000MiB). Your application data set seems too huge to fit on the device,
StarPU will cope by trying to purge 2 MiB out. This message will not be
printed again for further purges. The thresholds can be tuned using the
STARPU_MINIMUM_AVAILABLE_MEM and STARPU_TARGET_AVAILABLE_MEM environment
variables.
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x1cab04)[0x10000023ab04]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(starpu_unistd_o_direct_global_async_write+0x130)[0x10000023a3b0]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_disk_write+0x194)[0x1000000f39d4]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_disk_copy_src_to_disk+0x80)[0x100000185620]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(starpu_interface_copy+0x128)[0x100000197048]
.../starpu-svn/tests/datawizard/.libs/variable_size[0x10001db8]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x126a1c)[0x100000196a1c]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_driver_copy_data_1_to_1+0x150)[0x100000195ed0]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x12395c)[0x10000019395c]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x120150)[0x100000190150]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(__starpu_datawizard_progress+0x138)[0x100000195078]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_datawizard_progress+0x1c)[0x10000019537c]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_wait_data_request_completion+0x7c)[0x10000018efdc]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x13a79c)[0x1000001aa79c]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x137d2c)[0x1000001a7d2c]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(+0x134ea0)[0x1000001a4ea0]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(starpu_memchunk_tidy+0x1c0)[0x1000001a3ba0]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(__starpu_datawizard_progress+0x118)[0x100000195058]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_cuda_driver_run_once+0x250)[0x1000002355f0]
.../starpu-svn/src/.libs/libstarpu-1.3.so.0(_starpu_cuda_worker+0x60)[0x100000237020]
/lib64/libpthread.so.0(+0x8728)[0x1000035a8728]
/lib64/libc.so.6(clone+0x98)[0x100003c9d210]
[starpu][starpu_unistd_o_direct_global_async_write][assert failure] The
unistd_o_direct variant can only write a multiple of page size 65536 Bytes
(Here 2183168). Use the non-o_direct unistd variant if your data is not a
multiple of 65536
variable_size: core/disk_ops/disk_unistd_o_direct.c:95: void
*starpu_unistd_o_direct_global_async_write(void *, void *, void *, off_t,
size_t): Assertion `(size % getpagesize()) == 0' failed.
[error] `./datawizard/variable_size' killed with signal 6; test marked as
failed
while looking for core file of ./datawizard/variable_size: core.124854: No
such file or directory
while looking for core file of ./datawizard/variable_size: core: No such file
or directory
#Execution_time_in_seconds 9.174380 ./datawizard/variable_size
FAIL datawizard/variable_size (exit status: 1)
FAIL: disk/mem_reclaim
>From mem_reclaim.log:
[starpu][17592186347216][_starpu_submit_job:core/task.c@378] <--
[error] `./disk/mem_reclaim' killed with signal 11; test marked as failed
while looking for core file of ./disk/mem_reclaim: core.2331: No such file or
directory
while looking for core file of ./disk/mem_reclaim: core: No such file or
directory
#Execution_time_in_seconds 6.591819 ./disk/mem_reclaim
FAIL disk/mem_reclaim (exit status: 1)
with these tests skipped or expected to fail:
SKIP: main/static_restartable_using_initializer
SKIP: datawizard/interfaces/multiformat/advanced/multiformat_cuda_opencl
SKIP: datawizard/readonly
XFAIL: errorcheck/invalid_blocking_calls
Thank you for a quick response,
Vedran
________________________________________
Sent: 20 June 2017 14:53
To: Novakovic, Vedran (STFC,DL,HC)
vedran.novakovic@stfc.ac.uk, on mar. 20 juin 2017 13:45:55 +0000, wrote:
> Has anyone had any experience with StarPU on IBM Power8 systems (little
> endian, running Red Hat, using IBM's XL compilers)?
> Does it build on such configuration at all and are there any special
> tweaking efforts or source patches needed?
> How about CUDA and MPI support?
Nothing special should be needed. StarPU is tested on all Debian
architectures, for instance.
Samuel
- [Starpu-devel] StarPU on IBM Power8 systems, vedran.novakovic, 20/06/2017
- Re: [Starpu-devel] StarPU on IBM Power8 systems, Samuel Thibault, 20/06/2017
- Re: [Starpu-devel] StarPU on IBM Power8 systems, vedran.novakovic, 20/06/2017
