Archives de la liste
- To: Kadir Akbudak <kadir.akbudak@kaust.edu.sa>
- Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] StarPU will cope by trying to purge
- Date: Mon, 26 Jun 2017 08:32:13 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
Kadir Akbudak, on jeu. 22 juin 2017 10:12:36 +0300, wrote:
> I get lots of the following error and my program stalls forever:
> [starpu][_starpu_mktemp] Could not create temporary file in directory
> '/tmp/448/455', mskostemp failed with error 'Invalid argument'
> The reason may be that the compute nodes of the Cray XC40 system that
> I use may not have /tmp. In fact compute nodes do not have disks at
> all.
Ok, so OOC is really not an option.
> I will investigate throttling task submission with the
> STARPU_LIMIT_MAX_SUBMITTED_TASKS environment variable.
That's currently the only way to limit the amount of data allocation for
MPI receives, yes.
> Regarding the shared memory system with 256GiB, I only run unix top
> program so I might have missed the spikes in memory consumption. What
> is the best way to show real memory consumption of StarPU?
The paje.trace file as opened in vite shows memory use in the MEMMANAGER
line.
> I tried to use starpu_data_display_memory_stats(), but it prints only
> "Memory stats :" and nothing else.
That indeed only displays some details on the registered data handles,
not global memory consumption.
Samuel
- [Starpu-devel] StarPU will cope by trying to purge, Kadir Akbudak, 20/06/2017
- Re: [Starpu-devel] StarPU will cope by trying to purge, Samuel Thibault, 20/06/2017
- Re: [Starpu-devel] StarPU will cope by trying to purge, Kadir Akbudak, 22/06/2017
- Re: [Starpu-devel] StarPU will cope by trying to purge, Samuel Thibault, 26/06/2017
- Re: [Starpu-devel] StarPU will cope by trying to purge, Kadir Akbudak, 26/06/2017
- <Suite(s) possible(s)>
