Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU will cope by trying to purge
Archives de la liste
Chronologique Discussions
  • To: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] StarPU will cope by trying to purge
  • Date: Mon, 26 Jun 2017 11:32:54 +0300
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=kadir.akbudak@kaust.edu.sa; spf=Pass smtp.mailfrom=kadir.akbudak@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-it0-f45.google.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear Samuel,
I will look at paje.trace files that I have already obtained.
Very thanks for your guidence.
Best regards,
Kadir
On Jun 26, 2017 09:32, "Samuel Thibault" <samuel.thibault@inria.fr> wrote:
Hello,
Kadir Akbudak, on jeu. 22 juin 2017 10:12:36 +0300, wrote:
> I get lots of the following error and my program stalls forever:
> [starpu][_starpu_mktemp] Could not create temporary file in directory
> '/tmp/448/455', mskostemp failed with error 'Invalid argument'
> The reason may be that the compute nodes of the Cray XC40 system that
> I use may not have /tmp. In fact compute nodes do not have disks at
> all.
Ok, so OOC is really not an option.
> I will investigate throttling task submission with the
> STARPU_LIMIT_MAX_SUBMITTED_TASKS environment variable.
That's currently the only way to limit the amount of data allocation for
MPI receives, yes.
> Regarding the shared memory system with 256GiB, I only run unix top
> program so I might have missed the spikes in memory consumption. What
> is the best way to show real memory consumption of StarPU?
The paje.trace file as opened in vite shows memory use in the MEMMANAGER
line.
> I tried to use starpu_data_display_memory_stats(), but it prints only
> "Memory stats :" and nothing else.
That indeed only displays some details on the registered data handles,
not global memory consumption.
Samuel
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
Haut de le page
