Archives de la liste
- To: Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
- Cc: Negin Bagherpour <negin.bagherpour@manchester.ac.uk>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Jakub Sistek <jakub.sistek@manchester.ac.uk>
- Subject: Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL
- Date: Thu, 14 Sep 2017 15:51:20 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Mawussi,
The main difference between StarPU used alone and StarPU used through the
OpenMP compatibility layer concerns the 'main' thread of the application:
- When StarPU is used alone on a N-core machine, it launches N worker threads
bound on the N cores. (Thus there is a total of N+1 threads: 1 main
application thread + N StarPU workers) The main application thread is only
used for submitting tasks to StarPU, it does not execute tasks and it is not
bound to a core unless the application binds it explicitly.
- When StarPU is used through the OpenMP compatibility layer on a N-core, it
launches N-1 worker threads bounds to N-1 cores. (Thus there is a total of N
threads: 1 main application thread + N-1 StarPU workers) The main application
thread is used for submitting tasks _and_ for participating in task execution
while blocked on some barrier (e.g.: omp taskwait, implicit barriers at end
of parallel regions, ...). This behaviour is required for compliance with the
OpenMP execution model.
I am not sure whether this difference is the unique cause of the performance
mismatch you observed, but this probably count for some significant part at
least, generally in favor of the StarPU+OpenMP. This may be the main factor
for the difference on small matrices, where the main thread of the
StarPU+OpenMP version can quickly give an hand to the computation, while the
main thread for the native StarPU version must first be de-scheduled by the
OS Kernel to leave its core to a worker thread.
On the other hand, the management of tasks for StarPU+OpenMP is more
expensive than the management of StarPU native tasks, due to the fact that
StarPU+OpenMP tasks may block while native StarPU tasks never block. This
management difference is therefore in favor of the native StarPU version.
This additional management cost is perhaps more expensive on the KNL where
the cores are much less advanced than the regular Intel xeon cores.
I do not know why the GFLOPS drop sharply for dgemm.KNL for matrix size >=
14000. Only could think about some NUMA issue, but this should not be the
case since you say that the matrix is allocated in MCDRAM.
I do not know either why the StarPU+OpenMP plot and the native StarPU plot
cross for the dpotrf.KNl test case.
How do you choose the block size for each test sample ? Is it fixed for all
matrix sizes or is it computed from the matrix size? Do you observe very
different behaviour for other block sizes (e.g. fewer tasks on large blocks,
more tasks on small blocks, ...)?
Best regards,
Olivier
> Le 14 sept. 2017 à 11:00, Mawussi Zounon <mawussi.zounon@manchester.ac.uk>
> a écrit :
> Dear all,
> Recently we developed a new version of the PLASMA library fully based on
> the OpenMP task-based
> runtime system. Our benchmark on both regular Intel Xeon (Haswell and
> Broadwell in the experiment) and Intel KNL, showed that the new OpenMP
> PLASMA has a performance comparable to the old version based on QUARK. This
> motivated us to extend the experiment to StarPU.
> To this end, on one hand we used KSTAR to generate a StarPU version of
> PLASMA. On another hand we developed another version of PLASMA (restricted
> to a few routines) based StarPU.
> It is important to note that the algorithms are the same; we simply
> replaced the task-based runtime system. Below are our findings:
> • On regular Intel Xeon architectures, PLASMA_OpenMP (OMP)
> PLASMA_KSTAR (KSTAR), and PLASMA_HAND_WRITTEN_STARPU (STARPU) have
> comparable performance, except for very small size matrices where our hand
> written StarPU version of PLASMA is outperformed by the generic KSTAR.
> • On the Intel Self-hosted KNL (68 cores), both our own STARPU
> version and KSTAR are significantly slow compared to OMP. But again our
> KSTAR and our StarPU version exhibited difference performance behaviour.
> I am wondering whether you can provide us with some hints or guidance to
> improve the performance of StarPU on the Intel KNL architecture. There
> might be some configuration options I missed. In addition I will be happy
> if you can help us to understand why our StarPU version seemed more
> penalized for small size matrices while KSTAR seems to be doing relatively
> better.
> Below some performance charts of dgemm and Cholesky (dpotrf) to illustrate
> our observations:
> <dgemm_haswell_rutimes.png>
> <dpotrf_haswell_rutimes.png>
> <dgemm_knl_rutimes.png>
> <dpotrf_knl_rutimes.png>
> For the experiments on KNL, the matrices have been allocated in the MCDRAM.
> I am looking forward to hearing from you.
> Best regards,
> --Mawussi
smime.p7s
Description: S/MIME cryptographic signature
- [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 14/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 14/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 15/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 15/09/2017
- Message indisponible
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 18/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 18/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 19/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Samuel Thibault, 19/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 20/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Olivier Aumage, 20/09/2017
- Re: [Starpu-devel] Performance issue of StarPU on Intel self-hosted KNL, Mawussi Zounon, 21/09/2017
