Archives de la liste
- To: Yihong Gao <yihong.gao@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim
- Date: Thu, 28 Sep 2017 11:20:45 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Yihong Gao, on jeu. 28 sept. 2017 11:16:54 +0200, wrote:
> I'm running an experiment on Chameleon+StarPU. I use the Mirage server on
> Plafrim, but the StarPU cannot find the GPUs of the server. The results are
> as
> follows:
> [ygao@mirage06 ~]$ $(spack location -i chameleon~simu)/lib/chameleon/timing/
> time_dgeqrf_tile --gpus=3 --trace --nb=960 --ib=96 --n_range=15360:15360:1
> --niter=10
> [starpu][starpu_initialize] Warning: StarPU was configured with --with-fxt,
> which slows down a bit, limits scalability and makes worker initialization
> sequential
> [starpu][_starpu_init_machine_config] Warning: 3 CUDA devices requested.
> Only 0
> available.
Please see in the documentation, in the FAQ section "StarPU does not
see my CUDA device", the test to run to make sure whether it's a StarPU
issue or a CUDA issue (in which latter case it's the plafrim people you
should contact)
Samuel
- [Starpu-devel] StarPU cannot find GPUs on Plafrim, Yihong Gao, 28/09/2017
- Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim, Samuel Thibault, 28/09/2017
- Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim, Lionel Eyraud-Dubois, 28/09/2017
- Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim, Nathalie Furmento, 28/09/2017
