Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim
Archives de la liste
Chronologique Discussions
  • From: Lionel Eyraud-Dubois <lionel.eyraud-dubois@inria.fr>
  • To: Samuel Thibault <samuel.thibault@inria.fr>, starpu-devel@lists.gforge.inria.fr
  • Cc: Yihong Gao <yihong.gao@inria.fr>
  • Subject: Re: [Starpu-devel] StarPU cannot find GPUs on Plafrim
  • Date: Thu, 28 Sep 2017 12:06:55 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=lionel.eyraud-dubois@inria.fr; spf=None smtp.mailfrom=lionel.eyraud-dubois@inria.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-phdr: 9a23:+UhBFRBlNjHMpjVHKJQOUyQJP3N1i/DPJgcQr6AfoPdwSP7+ocbcNUDSrc9gkEXOFd2Crakb26yL6+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6lX71zMZGw3+OAxpPay1X9eK14Xkn9y1rqbaZhhFgHKBYbJ4JQiysU2FrcATnIZmbLoxyxHAv39UU+VQ32JhY1yJyVK0/du55oZ+tihdpf8l38pBSrnhOas2SqZXAXInNXo07Yvlr0rtVwyKs18dVWMbllJlEhLM8R2/cor7tSrh/r552S6cMMmwQKEuUCmuqqt2Qhjpkw8GMSQ4+SfZkJoj3+pgvBu9qkknkMbva4aPOa87J/uFcA==
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
On 28/09/2017 11:20, Samuel Thibault wrote:
Yihong Gao, on jeu. 28 sept. 2017 11:16:54 +0200, wrote:
I'm running an experiment on Chameleon+StarPU. I use the Mirage server on
Plafrim, but the StarPU cannot find the GPUs of the server. The results are as
follows:
[ygao@mirage06 ~]$ $(spack location -i chameleon~simu)/lib/chameleon/timing/
time_dgeqrf_tile --gpus=3 --trace --nb=960 --ib=96 --n_range=15360:15360:1
--niter=10
[starpu][starpu_initialize] Warning: StarPU was configured with --with-fxt,
which slows down a bit, limits scalability and makes worker initialization
sequential
[starpu][_starpu_init_machine_config] Warning: 3 CUDA devices requested. Only 0
available.
Please see in the documentation, in the FAQ section "StarPU does not
see my CUDA device", the test to run to make sure whether it's a StarPU
issue or a CUDA issue (in which latter case it's the plafrim people you
should contact)
Samuel
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Thanks for this ! Indeed it was a CUDA problem, mismatch in versions of CUDA (sirocco has v90, mirage has v75). By the way, the code included in the FAQ is not complete : the #include statements at the top are not there, maybe including them would help newbies be more autonomous ;)
Thanks again,
Lionel.
Haut de le page
