Archives de la liste
- To: Maxim Abalenkov <maxim.abalenkov@gmail.com>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
- Date: Thu, 28 Dec 2017 20:09:17 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Fail smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Maxim Abalenkov, on jeu. 28 déc. 2017 20:47:04 +0200, wrote:
> STARPU_DATA_MODE_ARRAY, panel_desc, A.mt,
> My only problem is to unpack the tiles and the pivots vector together, one
> after another inside the CPU kernel function. I can’t achieve this. Thank
> you.
data arrays appear merely as data, one after the other, in the descr
parameter, see for instance tests/main/insert_task_dyn_handles.c
Samuel
- Re: [Starpu-devel] [LU factorisation: gdb debug output], (suite)
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Samuel Thibault, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 21/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 28/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Samuel Thibault, 28/12/2017
