Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] [LU factorisation: gdb debug output]
- Date: Wed, 20 Dec 2017 14:46:53 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-wm0-f45.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hello Samuel,
Please find below the gdb output after switching to the crashing thread:
(gdb) thread 3
[Switching to thread 3 (Thread 0x7fffeecde700 (LWP 27673))]
#0 0x00007ffff31ca860 in raise () from /usr/lib/libc.so.6
(gdb) frame 8
#8 0x00007ffff73bd75e in _starpu_fetch_task_input (j=0x555555a5ed40) at datawizard/coherency.c:972
972 ret = fetch_data(handle, node, local_replicate, mode);
(gdb) print node
$1 = 1
(gdb) print local_memory_node
$2 = 0
(gdb) print descrs[index].node
$3 = 1
Best wishes,
Maxim
On 20 Dec 2017, at 14:42, Samuel Thibault <samuel.thibault@inria.fr> wrote:Maxim Abalenkov, on mer. 20 déc. 2017 14:41:14 +0100, wrote:Please find attached the output of the gdb commands that you suggested. It seems there is no node.
I meant to adapt the thread number according to the stack, since the
fault will not necessarily happen always in the same thread.
Samuel
- [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Samuel Thibault, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 20/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 21/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Maxim Abalenkov, 28/12/2017
- Re: [Starpu-devel] [LU factorisation: gdb debug output], Samuel Thibault, 28/12/2017
