Archives de la liste
- To: Nathalie Furmento <nathalie.furmento@labri.fr>
- Subject: Re: [Starpu-devel] Nouvelle politique d'ordonnancement
- Date: Fri, 23 Mar 2018 13:28:25 +0100 (CET)
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
- Ironport-phdr: 9a23:4T0ZHxPKZ7OczBE8U3gl6mtUPXoX/o7sNwtQ0KIMzox0I/75rarrMEGX3/hxlliBBdydt6ofzbKO+4nbGkU4qa6bt34DdJEeHzQksu4x2zIaPcieFEfgJ+TrZSFpVO5LVVti4m3peRMNQJW2aFLduGC94iAPERvjKwV1Ov71GonPhMiryuy+4ZLebxlGiTanfb9+MAi9oBnMuMURnYZsMLs6xAHTontPdeRWxGdoKkyWkh3h+Mq+/4Nt/jpJtf45+MFOTav1f6IjTbxFFzsmKHw65NfqtRbYUwSC4GYXX3gMnRpJBwjF6wz6Xov0vyDnuOdxxDWWMMvrRr0vRz+s87lkRwPpiCcfNj427mfXitBrjKlGpB6tvgFzz5LIbI2QMvd1Y6HTcs4ARWdZUMhfVzJPDIC+YIsBEuQOMvpXr4j6qVsSthaxHxWgC//1xzJSmnP736s32PkhHwHc2wwgGsoDv27SrNXzKqgZTPy6w7PTzTrda/NW3Tb945XPfx87p/GMW6x/fdDNxkY1DAPKkFGQqYjkPz6OyOsNtXOb4PR6Wu61hW4nsRh8rz6yzckijYnJg5gaylHC9ShhwYY1I8e4SE9hbtK+HptQrTmWN49sTcw5WWFouTw2yrMcuZO9YSMEy4wnygbCZ/GIcYWE+AzvWPuNLTtimn5pZbKyiwys/US80uHwS8253VlQoiZbktTBuWoB2wLc58SZUPdx41+t1SuL2g3c8O1IP0A5mKXBJ5I/zbM8i4AfvErfEiLwhU74lrWZdl8+9eit8+nnYqvpppubN4JslAHyK6Uvms26AeQ9LggBRXSX9fqm2L3+5EH2W7JKjucrnabHqp/aOMsaqrS3Aw9Pyooj6hC/ACm60NkAgHUKI1BIdAiZg4T0J13COu70Aeq/jli2jjtn2+jKPrj7DZXMKnjDnq3hfbF460NEzgo818xf55JOBbEFIfL8RFX9tNLFDh8jNgy73eDnCMl61o4FXWKAGLSWMLnTsVOS6OIvOfGAZJUJtzblN/gl+/nugGcimV8BZ6apx4MXaG2hEvt7PUqZf2TjgtMaHGcOvwo+V/DqiEaYXT5caXayWLg85j4lB468DIfDQJqtgL2b0yuhEJ1WfDMONlfZN370d4yAWvpERj+IJ8JnjjtMAb6oV48o0RCj8gHn0b9qKPbT0ikRv4jiktZvsb79jxY3oDVyCcnV2GiWQmVwnytcTjkw0eZ0qFdwzlOC+aV+mPFRU9JJsaAaGjwmPILRmrQpQ+v5XRjMK5LQEA7/E4eWRAopR9d0+OcgJkN0GtGslBfGhnL4B7Yfjb3NCoZmqvuAjUi0HN50zjP97Idkl0MvG5MdMWSsnK85+RKBX9eUwXXcrL6jcOEn5ACI9GqHyjDQ7l8dQg91VLnMBSpZew7cqs7160rfX/mgE+Z/Pw==
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Resent-date: Fri, 23 Mar 2018 13:29:30 +0100
- Resent-from: Nathalie Furmento <nathalie.furmento@labri.fr>
- Resent-message-id: <c1c8d582-cc14-af8f-1f13-1f13b134bae3@labri.fr>
- Resent-to: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
- Resent-user-agent: Mozilla/5.0 (X11; Linux x86_64; rv:52.0) Gecko/20100101 Thunderbird/52.6.0
Merci beaucoup pour votre réponse rapide !
Dans ce cas, pourquoi ces lignes n'apparaissent pas dans les politiques d'ordonnancement proposées ? Les fichiers de code ne proposent que la structure ainsi que les fonctions pointées. Ces lignes figurent-elles alors autre part ?
Merci,
Anne.
De: "Nathalie Furmento" <nathalie.furmento@labri.fr>
À: "anne caselli" <anne.caselli@ensea.fr>, "starpu-devel" <starpu-devel@lists.gforge.inria.fr>
Envoyé: Vendredi 23 Mars 2018 13:09:47
Objet: Re: [Starpu-devel] Nouvelle politique d'ordonnancement
Bonjour,
L'application examples/scheduler/dummy_sched.c montre comment utiliser son propre ordonnanceur.
Après avoir défini la structure avec tous les pointeurs de fonction, on peut utiliser starpu_conf_init pour l'utiliser.
starpu_conf_init(&conf);
conf.sched_policy = &dummy_sched_policy,
ret = starpu_init(&conf);
(http://starpu.gforge.inria.fr/doc/html/Scheduling.html#DefiningANewSchedulingPolicy)
Cordialement,
Nathalie
Cordialement,
Nathalie
1294002505.6683563.1521806508385.JavaMail.zimbra@ensea.fr">Bonjour,
Tout d'abord merci pour l'aide apportée lors de mon précédent message.
Je dois dans le cadre du même projet de recherche, développer une nouvelle politique d'ordonnancement. Pour l'instant je cherche juste à bien comprendre comment ajouter une nouvelle politique. Dans mon cas, j'ai créé un nouveau fichier dans lequel j'ai repris le code de "work_stealing_policy" mais j'ai modifié le nom de la structure de type starpu_sched_policy ainsi que de ses champs "policy_name" et "policy_description", comme s'il s'agissait d'une nouvelle politique. J'ai donc modifié en conséquence les fichiers sched_policy.c et sched_policy.h dans lesquels sont référencées les politiques, ainsi que les makefile. Je n'ai pas d'erreurs de compilation, ni d'installation. Mais lorsque j'essaie d’exécuter un de mes codes avec cette politique, il ne se passe rien. Alors que si je choisis la politique work_stealing_policy, mon code s’exécute correctement. Je me demande donc si je n'ai pas loupé quelque chose que j'aurais du modifier ou ajouter à l'ajout d'une politique.
Merci d'avance pour votre aide!
Cordialement,
Anne CASELLI
_______________________________________________ Starpu-devel mailing list Starpu-devel@lists.gforge.inria.fr https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
-- Dr Nathalie Furmento Ingénieur de recherche CNRS http://www.labri.fr/~furmento/ LaBRI - Université Bordeaux
- [Starpu-devel] Nouvelle politique d'ordonnancement, anne caselli, 23/03/2018
- Re: [Starpu-devel] Nouvelle politique d'ordonnancement, Nathalie Furmento, 23/03/2018
- Re: [Starpu-devel] Nouvelle politique d'ordonnancement, anne caselli, 23/03/2018
