Archives de la liste
Re: [Starpu-devel] [Morse-devel] segfault occurring with starpu 1.2.3 and master branch of chameleon
Chronologique Discussions
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "morse-devel@lists.gforge.inria.fr" <morse-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] [Morse-devel] segfault occurring with starpu 1.2.3 and master branch of chameleon
- Date: Sat, 24 Mar 2018 02:59:09 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=4621ba20b2=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Sam,
it worked like a charm, thanks!
You probably told me million time the answer to this question.
Which version should I use from StarPU, which contains the most up to date patches?
I am currently downloading the tarball from http://starpu.gforge.inria.fr/files/.
Should I get the latest version on git (git clone
https://scm.gforge.inria.fr/anonscm/git/starpu/starpu.git StarPU) and then switch to a particular branch?
Best,
H
On Mar 23, 2018, at 7:04 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Hatem Ltaief, on sam. 24 mars 2018 01:53:39 +0000, wrote:
I am facing a segfault raised by chameleon runtime_descriptor.c when handling
MPI tags, due to a bad value returned by the new function
starpu_mpi_comm_get_attr for fixing the MPI tag issue, introduced in starpu
1.2.3.
It was bogus indeed, this was fixed in the 1.2 branch with the attached
patch.
Samuel
<patch.txt>
This message and its contents including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
- [Starpu-devel] segfault occurring with starpu 1.2.3 and master branch of chameleon, Hatem Ltaief, 24/03/2018
- Re: [Starpu-devel] [Morse-devel] segfault occurring with starpu 1.2.3 and master branch of chameleon, Samuel Thibault, 24/03/2018
- Re: [Starpu-devel] [Morse-devel] segfault occurring with starpu 1.2.3 and master branch of chameleon, Hatem Ltaief, 24/03/2018
