Archives de la liste
Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
Chronologique Discussions
- To: Aniello Esposito <esposito@cray.com>
- Cc: Kadir Akbudak <kadir.akbudak@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, Aleksandr Mikhalev <aleksandr.mikhalev@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems
- Date: Wed, 2 May 2018 19:30:13 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Aniello Esposito, le mer. 02 mai 2018 17:08:48 +0000, a ecrit:
> As Hatem already emphasized, the main point here is the behavior of threads
> in the presence of not enough work. We would have expected no real
> difference if even
> too many threads are used.
Sure, but that's precisely where a centralized scheduler like prio would
suffer from all the idle threads trying to pick up work from the central
place, tasks getting executed randomly on various CPUs, etc.
Samuel
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Aniello Esposito, 02/05/2018
- Re: [Starpu-devel] Performance profiling of tile low rank cholesky (HiCMA) with StarPU on distributed memory systems, Samuel Thibault, 02/05/2018
