Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Passing a structure to starpu insert task
Archives de la liste
Chronologique Discussions
  • To: Samuel Thibault <samuel.thibault@inria.fr>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Passing a structure to starpu insert task
  • Date: Wed, 2 May 2018 18:41:35 +0000
  • Accept-language: en-GB, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=66605afa75=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
solved, thx!
H
> On May 1, 2018, at 12:56 PM, Samuel Thibault <samuel.thibault@inria.fr>
> wrote:
> Hatem Ltaief, le mar. 01 mai 2018 09:54:44 +0000, a ecrit:
>> I am trying to pass a single data structure (composed of int, float,
>> etc...) to a starpu insert task API using STARPU_VALUE. Is that the right
>> way to do it for data structures?
> You can pass both the pointer to the structure and the size of the
> structure, yes.
> Samuel
________________________________
This message and its contents including attachments are intended solely for
the original recipient. If you are not the intended recipient or have
received this message in error, please notify me immediately and delete this
message from your computer system. Any unauthorized use or distribution is
prohibited. Please consider the environment before printing this email.
Haut de le page
