Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] exposing the task color field to starpu-task-insert
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Amani Alonazi <amani.alonazi@kaust.edu.sa>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] exposing the task color field to starpu-task-insert
  • Date: Mon, 25 Jun 2018 12:00:21 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta03.u-bordeaux.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Thanks for the patch, i renamed STARPU_COLOR into STARPU_TASK_COLOR.
The master and the 1.2 branch now have a STARPU_TASK_COLOR value to be used in starpu_task_insert & co functions.
Cheers,
Nathalie
On 25/06/2018 10:06, Amani Alonazi wrote:
Thanks Samuel,
Please find a patch for exposing the task->color field to task-insert utility attached here.
Thanks and Bye for now,
A.
On Sun, Jun 24, 2018 at 3:21 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
Hello,
Amani Alonazi, le dim. 24 juin 2018 11:37:19 +0300, a ecrit:
> I made few modifications to starpu-1.2.4 in order to expose the task color
> field to starpu-task-insert utility. is there a way to do a pull request to
> this repo:
> [1]https://scm.gforge.inria.fr/anonscm/git/starpu/starpu.git
> Or is there an official github repo of starpu?
We do not have pull request possibilities.
But you can simply send your patch to this list, and we will happily
apply it :)
Samuel
This message and its contents, including attachments are intended solely for the original recipient. If you are not the intended recipient or have received this message in error, please notify me immediately and delete this message from your computer system. Any unauthorized use or distribution is prohibited. Please consider the environment before printing this email.
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Dr Nathalie Furmento               Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/     LaBRI - Université Bordeaux
Haut de le page
