Archives de la liste
- To: Adrien Roussel Fraunhofer ITWM <adrien.roussel@itwm.fraunhofer.de>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Dépendances dynamiques
- Date: Tue, 3 Jul 2018 19:22:37 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23:iL+J8h8kOj+OXf9uRHKM819IXTAuvvDOBiVQ1KB31eIcTK2v8tzYMVDF4r011RmVBduds6oMotGVmpioYXYH75eFvSJKW713fDhBt/8rmRc9CtWOE0zxIa2iRSU7GMNfSA0tpCnjYgBaF8nkelLdvGC54yIMFRXjLwp1Ifn+FpLPg8it2O2+55zebx9UiDahfLh/MAi4oQLNu8cMnIBsMLwxyhzHontJf+RZ22ZlLk+Nkhj/+8m94odt/zxftPw9+cFAV776f7kjQrxDEDsmKWE169b1uhTFUACC+2ETUmQSkhpPHgjF8BT3VYr/vyfmquZw3jSRMNboRr4oRzut86ZrSAfpiCgZMT457HrXgdF0gK5CvR6tuwBzz4vSbYqINvRxY7ndcMsUS2RBQMhfSi9PAo2zYIQTEuUPMuRXr47zqFYVsRuzBhWgCP/zxjJShHL727Ax3eQ7EQHB2QwtB88Av27RrNXoKqgSVf2+wrfIzTXCdPxZwyr96IzUchs8pvyMRqh/cc/MyUYxEwPJlEmQqYzkPzyOzOsNrmyb7/Z7WOKujW4nsQBxrSK1yscikInEn4QYwU3H+yVh2Is5ON61RU5hbdK6HpZduTuWO5ZqTs8+WW1kpT42xqAatZO/ZiQG1ZAqywLFZ/CZc4WF7AjvWPuMLTp+mXlrYqiwhwyo/kil0uD8Vte70FJNriddktnDqGoN2AbJ5sedU/t940ah2TKR2ADV9O5EPVo4laTBK5I5w74wkIQcsVjbEyPrm0j7jLWaelsq9+Wm8ejrf6nqqoOGO4Npkg3+N74hms27AeQ2KAgOWG2b9Pyn1LL5+E35XatFjvksnqnFsJDaJN8UqbSkAw9RzoYu8AiwDzG90NgBmXkGLFVFeBSdg4juIVHOL+j0De2jjFS0jDdr2/fGM6X6ApXRNHfDiq/hfatk50FB1gUz085Q55ZPB7EFIfLzQVPxtMfCAh82PQy0xPznCNpj2Y8EWGKPBLWZMKLIvlOS6OIvObrEWIhAkTrnKvUjr8TpkGQilFtVU7OgwJ0Xb361BLxHH3q8KS7ljs0AHGFMpA0jV/fnjHWDTSFWIXioVr865jY1BZjgAYqVFa63h7nU5y6+A5BSLlxGC1qFDHP0P9GfUvIRZSbUPs9gmDUZUaSJSok71BjouhWsmOkvFfbd5iBN7cGr79Ny/eCG0EhqrWUlXfTY6HmESiRPpk1NQjY32K5lpkkklgWO17M9h+1fE5pU/fwbCF5mZ66Z9PRzDpXJYiyEZs2AEQ70Q9O8ADh3QMhjm4ZTMXY4IM2ri1X45wTvA7IRkOXaVpw56Kua1mHsJsJwzXvakqc73QAr
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Bonsoir,
Adrien Roussel Fraunhofer ITWM, le lun. 02 juil. 2018 23:21:57 +0200, a ecrit:
> J'ai réussi à reproduire le problème sur un ensemble d'opérations plus
> simple. Voici le main en question en PJ.
Ah, mais ce sont les mêmes structures de tâches qui sont soumises
plusieurs fois avec omp_kernel.process? Ça ne peut pas fonctionner
ainsi: StarPU stocke des informations sur l'exécution actuelle de la
tâche, ce qui ne permet donc pas de la réutiliser immédiatement.
- soit il faut utiliser d'autres structures de tâches
- soit il ne faut pas resoumettre les tâches, mais mettre le champ
regenerate à 1, pour que StarPU resoumette la tâche de lui-même quand
elle se termine. Pour s'arrêter, il faut juste à un moment mettre
regenerate à 0. Cf les exemples tests/main/ utilisant ce champ.
Samuel
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 02/07/2018
- <Suite(s) possible(s)>
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel Fraunhofer ITWM, 02/07/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 03/07/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel, 04/07/2018
- Re: [Starpu-devel] Dépendances dynamiques, Samuel Thibault, 04/07/2018
- Re: [Starpu-devel] Dépendances dynamiques, Adrien Roussel Fraunhofer ITWM, 03/07/2018
