Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Dépendances dynamiques
Archives de la liste
Chronologique Discussions
  • To: Adrien Roussel Fraunhofer ITWM <adrien.roussel@itwm.fraunhofer.de>
  • Cc: starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] Dépendances dynamiques
  • Date: Wed, 4 Jul 2018 09:52:31 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23:pmgOnRZVIQbp7ASipxHTMYD/LSx+4OfEezUN459isYplN5qZr8q8bnLW6fgltlLVR4KTs6sC17KI9fi4EUU7or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6arXK99yMdFQviPgRpOOv1BpTSj8Oq3Oyu5pHfeQpFiCa8bL9oMBm6sRjau9ULj4dlNqs/0AbCrGFSe+RRy2NoJFaTkAj568yt4pNt8Dletuw4+cJYXqr0Y6o3TbpDDDQ7KG81/9HktQPCTQSU+HQRVHgdnwdSDAjE6BH6WYrxsjf/u+Fg1iSWIdH6QLYpUjm58axlVAHnhzsGNz4h8WHYlMpwjL5AoBm8oxBz2pPYbJ2JOPZ7eK7WYNEUSndbXstJWSJPAp2yYZYMAeoPMulXs5TyqVQMohu5CwahH//vxzxUinPqwaE3yeYsHAfb1wIgBdIOt3HUoc3oOqgIVOC10bfHzTHeZP1I2Tf96ZPHfQo8ofGIQbJ7bM3cyVI1GAPAk1Wft4jlMymJ1uQNsmiU9PBvVf+ri247sAxxoz6vxt0tiobTnI4VxErE+Dx/zY0oJtO4UFZ2bcOnHZZQrS2WKYV7T804T211pCo21qcKtYOjcCQXx5kr2wTTZv6FfoSS/x7uWvydLSpmiH9qfr+0mgy8/lK6yuLmU8m5yFZKoTRBktnLrn0N1wLc6tKdRfdn5EihwCuP1wHX6u5aJ0A7i7bbJ4Qvwr4qjpYTsELDETHqmEjukaObdUUp9vK25+npbLjqvIKQO5Nohg3kL6gigsm/Dv45MggKUWib4+O81Lj78E3iWrpKi+A2nbfdsJzAOcQbpq+5DBRP3YY+7xa/Eyyr38oenXkcNV5FfBKGj4/vO13UJ/D4F/i/j0y2kDh33/DGIqHhApLVI3jYjLfuZ6x961ZByAYq0N9Q+YxUBa8FIP/oXk/xtcfYDgMiMwCuzObnBtJ91pkRWW2RGKOZMaXSsUWJ5u01OeWMapUV637BLK0M6+TvgHlxo1gAZrKk2dM5cnmlGPRhLUiDKVvQvfJJRW4GpAszSqrwj0CZSjNXT3euQKd66CsyFYSmConOXMahjerS8j28G8htb2VbB1TELXfpfYyZX+tEPDmbJ9JslnoYVbmrQpIlyTmvshX7wvxpNLyHqWUjqZv/2Y0ttKXonhYo+GkxVpzFijDffyRPhmoNAgQO8uV6qE15xE2E1PEk0fFeDplX9vRPFAAgOsyGlrAoO5XJQgvEO+yxZhO+WNz/WWMwSMgwypkAeRQlQojwvlX4xyOvRoQtufmLCZgzq/OO33XrLoB00mvH0KQngkVgTNEdbGA=
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Bonjour,
Adrien Roussel Fraunhofer ITWM, le mar. 03 juil. 2018 23:24:45 +0200, a ecrit:
> 1/ Si au lieu d'utiliser cette structure de tâche StarPU, j'utilise la
> fonction starpu_task_insert, ça passe ?
En fait starpu_task_insert est juste un helper pour un
starpu_task_create, le remplissage de la structure, et un
starpu_task_submit. Selon les cas ça peut être nécessaire de remplir la
structure à la main, mais si starpu_task_insert est plus
pratique/lisibile, autant l'utiliser.
> 2/ Si je garde ma structure actuelle, et que je passe par l'attribut
> regenerate... Comment faire pour ma tâche de réduction qui a un nombre
> variable d'arguments et que je lance via la fonction du runtime
> "starpu_task_insert" ?
> Car dans ce cas là, je construis pas explicitement ma tâche avec une
> structure starpu_task
Il est possible de soumettre l'instance suivante de la tâche depuis la
tâche elle-même.
Samuel
Haut de le page
