Archives de la liste
- To: Mathieu Faverge <mathieu.faverge@inria.fr>, starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Issue with lws
- Date: Fri, 14 Sep 2018 18:15:36 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Samuel Thibault, le ven. 14 sept. 2018 18:09:35 +0200, a ecrit:
> Mathieu Faverge, le ven. 14 sept. 2018 11:13:45 +0200, a ecrit:
> > When I'm lucky, I got this assert:
> > simple: core/dependencies/implicit_data_deps.c:446:
> > _starpu_release_data_enforce_sequential_consistency: Assertion
> > `task_dependency_slot->task == task' failed.
> This could look as if the same task gets executed twice, i.e. lws
> wouldn't lock properly when stealing. I have added assertions on task
> execution status in the 1.2 branch, could you try it?
To confirm that it's stealing which goes wrong, you could disable it by
making the select_victim() function in
src/sched_policies/locality_work_stealing_policy.c
just return -1;
Samuel
- [Starpu-devel] Issue with lws, Mathieu Faverge, 14/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 14/09/2018
- Re: [Starpu-devel] Issue with lws, Mathieu Faverge, 15/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 15/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 18/09/2018
- Re: [Starpu-devel] Issue with lws, Mathieu Faverge, 20/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 20/09/2018
