Archives de la liste
- To: Mathieu Faverge <mathieu.faverge@inria.fr>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Issue with lws
- Date: Sat, 15 Sep 2018 21:26:47 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Mathieu Faverge, le sam. 15 sept. 2018 15:10:22 +0200, a ecrit:
> Still the same asserts, the others you added are not triggered.
Hum, so it shouldn't be a task executed several times.
Did you try to run with a version of StarPU built with --enable-debug?
That adds a few more costly checks.
Samuel
- [Starpu-devel] Issue with lws, Mathieu Faverge, 14/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 14/09/2018
- Re: [Starpu-devel] Issue with lws, Mathieu Faverge, 15/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 15/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 18/09/2018
- Re: [Starpu-devel] Issue with lws, Mathieu Faverge, 20/09/2018
- Re: [Starpu-devel] Issue with lws, Samuel Thibault, 20/09/2018
