Archives de la liste
[Starpu-devel] [check data registered correctly, starpu_mpi_data_register]
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Subject: [Starpu-devel] [check data registered correctly, starpu_mpi_data_register]
- Date: Wed, 3 Oct 2018 15:00:32 +0100
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=maxim.abalenkov@gmail.com; spf=Pass smtp.mailfrom=maxim.abalenkov@gmail.com; spf=None smtp.helo=postmaster@mail-qk1-f175.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear all,
I would like to ask a relatively simple question. Is there a way to check, that the data has been registered correctly with the 'starpu_mpi_data_register()'? Please find below an error message, that I obtain. It seems the data has not been registered properly. What would be a good way to debug such an error? Thank you and have a good day ahead!
/opt/starpu/lib/libstarpumpi-1.3.so.0(starpu_mpi_data_get_rank+0x63)[0x7f38bad2abc3]
/opt/starpu/lib/libstarpumpi-1.3.so.0(_starpu_mpi_find_executee_node+0x40)[0x7f38bad2eab0]
/opt/starpu/lib/libstarpumpi-1.3.so.0(+0xe744)[0x7f38bad2f744]
/opt/starpu/lib/libstarpumpi-1.3.so.0(+0xed61)[0x7f38bad2fd61]
/opt/starpu/lib/libstarpumpi-1.3.so.0(starpu_mpi_task_insert+0xc9)[0x7f38bad30079]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libcoreblas.so(core_starpu_dgetrf_pnl+0x202)[0x7f38bae63cd6]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_pdgetrf+0x36e)[0x7f38bafccbed]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_starpu_dgetrf+0x23a)[0x7f38bafd6e3c]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_dgetrf+0x5d6)[0x7f38bafd6a65]
./test(+0x36dc8)[0x5610a8115dc8]
./test(+0xf970)[0x5610a80ee970]
./test(+0xf3bd)[0x5610a80ee3bd]
./test(+0xef03)[0x5610a80edf03]
/usr/lib/libc.so.6(__libc_start_main+0xf3)[0x7f38b4970223]
./test(+0x477e)[0x5610a80e377e]
[starpu][starpu_mpi_data_get_rank][assert failure] starpu_mpi_data_register MUST be called for data 0x5610a91f21a0
test: starpu_mpi.c:320: starpu_mpi_data_get_rank: Assertion `data->mpi_data' failed.
Best wishes,
Maxim
- [Starpu-devel] [check data registered correctly, starpu_mpi_data_register], Maxim Abalenkov, 03/10/2018
- Re: [Starpu-devel] [check data registered correctly, starpu_mpi_data_register], Nathalie Furmento, 04/10/2018
- Re: [Starpu-devel] [check data registered correctly, starpu_mpi_data_register], Samuel Thibault, 08/10/2018
