Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] [check data registered correctly, starpu_mpi_data_register]
Archives de la liste
Chronologique Discussions
  • From: Nathalie Furmento <nathalie.furmento@labri.fr>
  • To: Maxim Abalenkov <maxim.abalenkov@gmail.com>, starpu-devel@lists.gforge.inria.fr
  • Subject: Re: [Starpu-devel] [check data registered correctly, starpu_mpi_data_register]
  • Date: Thu, 4 Oct 2018 08:44:21 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=nathalie.furmento@labri.fr; spf=None smtp.mailfrom=nathalie.furmento@labri.fr; spf=None smtp.helo=postmaster@v-zimmta02.u-bordeaux.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hello,
Do you mean you would like a function starpu_mpi_data_is_registered(starpu_data_handle_t) ?
If your application calls starpu_mpi_data_register() then the data given in parameter is registered correctly within StarPU-MPI, the only information that could be missing would be the rank and and the tag.
Cheers,
Nathalie
On 03/10/2018 16:00, Maxim Abalenkov wrote:
Dear all,
I would like to ask a relatively simple question. Is there a way to check, that the data has been registered correctly with the 'starpu_mpi_data_register()'? Please find below an error message, that I obtain. It seems the data has not been registered properly. What would be a good way to debug such an error? Thank you and have a good day ahead!
/opt/starpu/lib/libstarpumpi-1.3.so.0(starpu_mpi_data_get_rank+0x63)[0x7f38bad2abc3]
/opt/starpu/lib/libstarpumpi-1.3.so.0(_starpu_mpi_find_executee_node+0x40)[0x7f38bad2eab0]
/opt/starpu/lib/libstarpumpi-1.3.so.0(+0xe744)[0x7f38bad2f744]
/opt/starpu/lib/libstarpumpi-1.3.so.0(+0xed61)[0x7f38bad2fd61]
/opt/starpu/lib/libstarpumpi-1.3.so.0(starpu_mpi_task_insert+0xc9)[0x7f38bad30079]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libcoreblas.so(core_starpu_dgetrf_pnl+0x202)[0x7f38bae63cd6]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_pdgetrf+0x36e)[0x7f38bafccbed]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_starpu_dgetrf+0x23a)[0x7f38bafd6e3c]
/home/mabalenk/repo/hg/plasma.starpu.lu-distr/lib/libplasma.so(plasma_dgetrf+0x5d6)[0x7f38bafd6a65]
./test(+0x36dc8)[0x5610a8115dc8]
./test(+0xf970)[0x5610a80ee970]
./test(+0xf3bd)[0x5610a80ee3bd]
./test(+0xef03)[0x5610a80edf03]
/usr/lib/libc.so.6(__libc_start_main+0xf3)[0x7f38b4970223]
./test(+0x477e)[0x5610a80e377e]
[starpu][starpu_mpi_data_get_rank][assert failure] starpu_mpi_data_register MUST be called for data 0x5610a91f21a0
test: starpu_mpi.c:320: starpu_mpi_data_get_rank: Assertion `data->mpi_data' failed.
Best wishes,
Maxim
_______________________________________________
Starpu-devel mailing list
Starpu-devel@lists.gforge.inria.fr
https://lists.gforge.inria.fr/mailman/listinfo/starpu-devel
Dr Nathalie Furmento               Ingénieure de recherche CNRS
http://www.labri.fr/~furmento/     LaBRI - Université Bordeaux
Haut de le page
