Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Passing a structure to starpu insert task
Archives de la liste
Chronologique Discussions
  • To: Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Cc: starpu-devel@lists.gforge.inria.fr, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Passing a structure to starpu insert task
  • Date: Mon, 15 Oct 2018 08:24:03 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Amani Alonazi, le lun. 15 oct. 2018 08:28:05 +0300, a ecrit:
> static void cl_x_cpu_func(void *descr[], void *cl_arg){
>   mystruct *s;
>   starpu_codelet_unpack_args(cl_arg, &x,
>                                      s
> If I change the code into:
>   mystruct s;
>                                      &s
> It works ok.
Well, yes: if you provide an uninitialized pointer to
starpu_codelet_unpack_args it will crash. You have to pass the address
of an existing structure.
Samuel
Haut de le page
