Archives de la liste
- To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
- Cc: starpu-devel@lists.gforge.inria.fr
- Subject: Re: [Starpu-devel] Passing a structure to starpu insert task
- Date: Sun, 14 Oct 2018 18:28:21 +0300
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f52.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear StarPU dev,
I have a question about passing a struct to StarPU codelet. If I pass it by reference to my function, I got Segmentation-fault error. MORSE_Task_x(..., mystruct* s){ ...
starpu_insert_task(
starpu_mpi_codelet(codelet),
STARPU_VALUE, s, sizeof(mystruct),
0);
Thread 8 "CPU 0" received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x7fffdaffd700 (LWP 27333)]
0x00007ffff7547dd9 in _starpu_job_get_data_size (model=0x300000001, arch=0x7ffff791ee50 <_starpu_config+4784>, impl=0, j=0x970d60) at core/perfmodel/perfmodel_history.c:198
198 if (model && model->state->per_arch && comb != -1 && model->state->per_arch[comb] && model->state->per_arch[comb][impl].size_base)
(gdb) bt
#0 0x00007ffff7547dd9 in _starpu_job_get_data_size (model=0x300000001, arch=0x7ffff791ee50 <_starpu_config+4784>, impl=0, j=0x970d60) at core/perfmodel/perfmodel_history.c:198
#1 0x00007ffff758f5ef in _starpu_driver_end_job (worker=0x7ffff791ee08 <_starpu_config+4712>, j=0x970d60, perf_arch=0x7ffff791ee50 <_starpu_config+4784>, rank=0, profiling=0) at drivers/driver_common/driver_common.c:131
#2 0x00007ffff76337fd in execute_job_on_cpu (j=0x970d60, worker_task=0x970910, cpu_args=0x7ffff791ee08 <_starpu_config+4712>, rank=0, perf_arch=0x7ffff791ee50 <_starpu_config+4784>) at drivers/cpu/driver_cpu.c:122
#3 0x00007ffff76345de in _starpu_cpu_driver_run_once (cpu_worker=0x7ffff791ee08 <_starpu_config+4712>) at drivers/cpu/driver_cpu.c:307
#4 0x00007ffff763495a in _starpu_cpu_worker (arg=0x7ffff791ee08 <_starpu_config+4712>) at drivers/cpu/driver_cpu.c:368
#5 0x00007fffedd826ba in start_thread (arg=0x7fffdaffd700) at pthread_create.c:333
#6 0x00007fffec86441d in clone () at ../sysdeps/unix/sysv/linux/x86_64/clone.S:109
(gdb) bt
However, if I pass it by value, the problem is solved. Am I missing something?
Thanks,
Amani
On Wed, May 2, 2018 at 9:41 PM Hatem Ltaief <hatem.ltaief@kaust.edu.sa> wrote:
solved, thx!
H
> On May 1, 2018, at 12:56 PM, Samuel Thibault <samuel.thibault@inria.fr> wrote:
> Hatem Ltaief, le mar. 01 mai 2018 09:54:44 +0000, a ecrit:
>> I am trying to pass a single data structure (composed of int, float, etc...) to a starpu insert task API using STARPU_VALUE. Is that the right way to do it for data structures?
> You can pass both the pointer to the structure and the size of the
> structure, yes.
> Samuel
Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Telephone: +966 (12) 808 0218
Mobile: +966 (0) 555191795
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
PhD Student
www.kaust.edu.sa
- Re: [Starpu-devel] Passing a structure to starpu insert task, Amani Alonazi, 14/10/2018
- Re: [Starpu-devel] Passing a structure to starpu insert task, Samuel Thibault, 14/10/2018
- Re: [Starpu-devel] Passing a structure to starpu insert task, Amani Alonazi, 15/10/2018
- Re: [Starpu-devel] Passing a structure to starpu insert task, Samuel Thibault, 15/10/2018
