Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Out of core limitations
Archives de la liste
Chronologique Discussions
  • To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>
  • Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Out of core limitations
  • Date: Thu, 18 Oct 2018 08:49:00 +0200
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hatem Ltaief, le jeu. 18 oct. 2018 05:54:40 +0000, a ecrit:
> There seems to be a limitation in using the OOC feature within chameleon.
> The matrix size needs to be a multiple of 32.
> Can you please explain why?
When using the unistd_o_direct back-end, yes. O_DIRECT can't work with
transfers not multiple of a page size.
> Can this be removed?
Using the unistd backend would avoid the constraint.
Samuel
Haut de le page
