Archives de la liste
- To: "Sameh M. Abdullah" <sameh.abdulah@kaust.edu.sa>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, Amani Alonazi <amani.alonazi@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Out of core limitations
- Date: Thu, 18 Oct 2018 13:06:15 +0200
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Sameh M. Abdullah, le jeu. 18 oct. 2018 11:30:00 +0300, a ecrit:
> Thanks Samuel, one more question. StarPU is creating a lot of files on
> disk for OOC. Is there any way to limit the number of generated files?
You can use the hdf5 format by setting hdf5 instead of unistd_o_direct.
Samuel
- [Starpu-devel] Out of core limitations, Hatem Ltaief, 18/10/2018
- Re: [Starpu-devel] Out of core limitations, Samuel Thibault, 18/10/2018
- Re: [Starpu-devel] Out of core limitations, Sameh M. Abdullah, 18/10/2018
