Accéder au contenu.
Menu Sympa
starpu-devel - [Starpu-devel] Support for half precision
Archives de la liste
Chronologique Discussions
  • To: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>
  • Cc: "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, "Nicolas L. Doucet" <nicolas.doucet@kaust.edu.sa>
  • Subject: [Starpu-devel] Support for half precision
  • Date: Fri, 19 Oct 2018 13:27:57 +0000
  • Accept-language: en-GB, en-US
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=183013500c=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Dear StarPU Team,
There is an explicit cuda support for half precision (16bits) to run on Volta
V100 GPU with tensor cores.
How should we proceed with StarPU to exploit this data type, as far as the
data transfer between GPUs is concerned?
This is rather a broad question. Any experience or example on this topic will
be welcome.
Thanks,
Hatem
Haut de le page
