Archives de la liste
- To: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: [Starpu-devel] CPU core binding mask and worker creation.
- Date: Wed, 24 Oct 2018 09:45:41 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi,
I have noticed that StarPU does not take into account the core/PU binding mask when it creates the worker threads. That is, if I launch my StarPU-based application by setting the binding mask (for example, hwloc-bind 0x00000001 ./my_application ...), then I always get as many worker threads as there are CPU cores in my machine and StarPU attempts to bind those worker threads to cores/PUs that are not in the binding mask. In most cases, a batch system sets the binding mask.
I have thus far solved the problem by setting the STARPU_WORKERS_NOBIND environmental variable to 1 and setting the correct number of workers manually.
I looked into StarPU source code base (1.2.6) and realized that I could fix the problem as follows:
1) Modify src/core/topology.c::_starpu_initialize_workers_bindid such that only those cores, that contain enough PUs that are in the PU binding mask (STARPU_NTHREADS_PER_CORE), are added to topology->workers_bindid.
2) Modify src/core/topology.c::_starpu_init_machine_config such that only those cores, that contain enough PUs that are in the PU binding mask, are counted in avail_cpus.
I have attached the patch to this email.
The modification seems to do the job (I also tested it with a hyperthreaded CPU) but the overall worker creating and binding process seems to be quite complex so I am not 100% sure about my modifications.
You are welcome to use the patch if you find it useful.
Best Regards,
Mirko Myllykoski
--- standard/src/core/topology.c 2018-09-21 11:18:04.000000000 +0200 +++ patched/src/core/topology.c 2018-10-23 20:53:19.059239797 +0200 @@ -672,6 +672,48 @@ int nhyperthreads = topology->nhwpus / topology->nhwcpus; STARPU_ASSERT_MSG(nth_per_core > 0 && nth_per_core <= nhyperthreads , "Incorrect number of hyperthreads"); +#ifdef STARPU_HAVE_HWLOC + hwloc_cpuset_t master = hwloc_bitmap_alloc(); + hwloc_get_cpubind(topology->hwtopology, master, HWLOC_CPUBIND_THREAD); + int j, avail; + + i = 0; /* Core number currently assigned */ + while (nbindids < STARPU_NMAXWORKERS) + { + /* Count how many PUs the core contains */ + avail = 0; + for (j = 0; j < nhyperthreads; j++) + { + if (hwloc_bitmap_isset(master, (i*nhyperthreads+j) % topology->nhwpus)) + { + avail++; + } + } + + /* Skip the core if it does not contain enough PUs */ + if (avail < nth_per_core) + { + i++; + continue; + } + + /* Map workers to the available PUs */ + k = 0; + for (j = 0; k < nth_per_core && nbindids < STARPU_NMAXWORKERS; j++) + { + if (hwloc_bitmap_isset(master, (i*nhyperthreads+j) % topology->nhwpus)) + { + topology->workers_bindid[nbindids] = (unsigned)((i*nhyperthreads+j) % topology->nhwpus); + nbindids++; + k++; + } + } + + i++; + } + + hwloc_bitmap_free(master); +#else i = 0; /* PU number currently assigned */ k = 0; /* Number of threads already put on the current core */ while(nbindids < STARPU_NMAXWORKERS) @@ -692,6 +734,7 @@ k++; i++; } +#endif } for (i = 0; i < STARPU_MAXCPUS;i++) @@ -1212,10 +1255,42 @@ unsigned already_busy_cpus = mic_busy_cpus + topology->ncudagpus + topology->nopenclgpus + topology->nsccdevices; + int nth_per_core = starpu_get_env_number_default("STARPU_NTHREADS_PER_CORE", 1); + +#ifdef STARPU_HAVE_HWLOC + hwloc_cpuset_t master = hwloc_bitmap_alloc(); + hwloc_get_cpubind(topology->hwtopology, master, HWLOC_CPUBIND_THREAD); + + unsigned i, avail; + unsigned nhyperthreads = topology->nhwpus / topology->nhwcpus; + + /* Count how many cores contain enough PUs */ + long avail_cpus = 0; + for (i = 0; i < topology->nhwcpus; i++) + { + avail = 0; + for (j = 0; j < nhyperthreads; j++) + { + if (hwloc_bitmap_isset(master, i * nhyperthreads + j)) + { + avail++; + } + } + + if (avail >= nth_per_core) + { + avail_cpus++; + } + } + + avail_cpus -= (long) already_busy_cpus; + + hwloc_bitmap_free(master); +#else long avail_cpus = (long) topology->nhwcpus - (long) already_busy_cpus; +#endif if (avail_cpus < 0) avail_cpus = 0; - int nth_per_core = starpu_get_env_number_default("STARPU_NTHREADS_PER_CORE", 1); avail_cpus *= nth_per_core; ncpu = STARPU_MIN(avail_cpus, STARPU_MAXCPUS); }
- [Starpu-devel] CPU core binding mask and worker creation., Mirko Myllykoski, 24/10/2018
- Re: [Starpu-devel] CPU core binding mask and worker creation., Samuel Thibault, 24/10/2018
- Re: [Starpu-devel] CPU core binding mask and worker creation., Mirko Myllykoski, 24/10/2018
