Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] CPU core binding mask and worker creation.
Archives de la liste
Chronologique Discussions
  • To: Mirko Myllykoski <mirkom@cs.umu.se>
  • Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
  • Subject: Re: [Starpu-devel] CPU core binding mask and worker creation.
  • Date: Wed, 24 Oct 2018 11:04:35 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mirkom@cs.umu.se; spf=Pass smtp.mailfrom=mirkom@cs.umu.se; spf=None smtp.helo=postmaster@mail.cs.umu.se
  • Ironport-phdr: 9a23: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
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
Hi
On 2018-10-24 10:55, Samuel Thibault wrote:
Mirko Myllykoski, le mer. 24 oct. 2018 10:50:09 +0200, a ecrit:
The current approach can lead to odd behavior if the binding mask is set to
something else that all available PUs. It seems that multiple workers end up
running on a same PU and StarPU does not even warn about that. I think that
the library should at least warn that this is happening.
? I believe there are such warnings in place already.
It seems that I get a warning when set STARPU_NCPU or STARPU_WORKERS_CPUID incorrectly.
However, hwloc-bind 0x00000001 ./my_application ... does not print any warnings. I get four workers (quad core CPU) and all workers seems to be bind to a single core (core #0 in this case). The execution time is also about four time longer than with hwloc-bind 0x0000000f ./my_application ....
- Mirko
Haut de le page
