Accéder au contenu.
Menu Sympa
starpu-devel - Re: [Starpu-devel] Support for half precision
Archives de la liste
Chronologique Discussions
  • To: Hatem Ltaief <hatem.ltaief@kaust.edu.sa>, "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, "Nicolas L. Doucet" <nicolas.doucet@kaust.edu.sa>
  • Subject: Re: [Starpu-devel] Support for half precision
  • Date: Thu, 31 Jan 2019 16:33:32 +0100
  • List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
  • List-id: "Developers list. For discussion of new features, code changes, etc." <starpu-devel.lists.gforge.inria.fr>
  • Organization: I am not organized
Hello,
Getting back to an old pending mail.
Samuel Thibault, le ven. 19 oct. 2018 17:24:57 +0200, a ecrit:
> Hatem Ltaief, le ven. 19 oct. 2018 15:20:24 +0000, a ecrit:
> > We would like to use a tile matrix in single precision to host tiles in
> > single precision as well as tiles in half precision. When about to
> > operate on tiles containing half precision data, then only half of the
> > data tile is meaningful, we would like starpu to transfer only the
> > meaningful data from the tiles when needed, ie full data tile for single
> > precision and half data tile for half precision.
> > Basically, you are saying that we can allocate our overall matrix with
> > tile data structure in single precision, and at the time of the starpu
> > data registration done on a tile-basis, we should specify the proper
> > element size.
> > Is that correct?
> Are the half-precision elements contiguous in memory?
>From what I see in the CUBLAS documentation for e.g. cublasHgemm, and SO
like
https://stackoverflow.com/questions/43120062/cuda-cublas-and-half-precision-data-types
https://stackoverflow.com/questions/32735292/can-anyone-provide-sample-code-demonstrating-the-use-of-16-bit-floating-point-in
they are contiguous. So the overall matrix with tile data structure
needs to be allocated in half precision, and registered to starpu with
the half-precision element size. Probably Chameleon needs to be extended
for that element size.
Now, when you want to mix both single precision and half-precision
parameters for the same task, you'll need to implement the corresponding
CUDA kernel.
Samuel
Haut de le page
