Archives de la liste
- To: Samuel Thibault <samuel.thibault@inria.fr>
- Cc: "starpu-devel@lists.gforge.inria.fr" <starpu-devel@lists.gforge.inria.fr>, "Sameh M. Abdulah" <sameh.abdulah@kaust.edu.sa>, "Nicolas L. Doucet" <nicolas.doucet@kaust.edu.sa>
- Subject: Re: [Starpu-devel] Support for half precision
- Date: Thu, 31 Jan 2019 20:51:26 +0000
- Accept-language: en-GB, en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=hatem.ltaief@kaust.edu.sa; spf=Pass smtp.mailfrom=prvs=593425f3d1=hatem.ltaief@kaust.edu.sa; spf=None smtp.helo=postmaster@mx08-0025e101.pphosted.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Hi Sam,
We have actually used half size of the 32bits tile from chameleon to stuff in
whole 16bits tile. All kernels run on GPUs/tensor cores.
This is a hack In chameleon while waiting for a mature bfloat support for
half precision on x86.
Thanks
Hatem
Sent from my iPhone
> On Jan 31, 2019, at 18:33, Samuel Thibault <samuel.thibault@inria.fr> wrote:
> Hello,
> Getting back to an old pending mail.
> Samuel Thibault, le ven. 19 oct. 2018 17:24:57 +0200, a ecrit:
>> Hatem Ltaief, le ven. 19 oct. 2018 15:20:24 +0000, a ecrit:
>>> We would like to use a tile matrix in single precision to host tiles in
>>> single precision as well as tiles in half precision. When about to
>>> operate on tiles containing half precision data, then only half of the
>>> data tile is meaningful, we would like starpu to transfer only the
>>> meaningful data from the tiles when needed, ie full data tile for single
>>> precision and half data tile for half precision.
>>> Basically, you are saying that we can allocate our overall matrix with
>>> tile data structure in single precision, and at the time of the starpu
>>> data registration done on a tile-basis, we should specify the proper
>>> element size.
>>> Is that correct?
>> Are the half-precision elements contiguous in memory?
> From what I see in the CUBLAS documentation for e.g. cublasHgemm, and SO
> like
> https://stackoverflow.com/questions/43120062/cuda-cublas-and-half-precision-data-types
> https://stackoverflow.com/questions/32735292/can-anyone-provide-sample-code-demonstrating-the-use-of-16-bit-floating-point-in
> they are contiguous. So the overall matrix with tile data structure
> needs to be allocated in half precision, and registered to starpu with
> the half-precision element size. Probably Chameleon needs to be extended
> for that element size.
> Now, when you want to mix both single precision and half-precision
> parameters for the same task, you'll need to implement the corresponding
> CUDA kernel.
> Samuel
- Re: [Starpu-devel] Support for half precision, Samuel Thibault, 31/01/2019
- Re: [Starpu-devel] Support for half precision, Hatem Ltaief, 31/01/2019
