Archives de la liste
[Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case
- Date: Mon, 11 Feb 2019 11:56:17 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f41.google.com
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
Dear starpu-dev,
A deadlock case (or extremely very very bad execution) is occurring from time to time. I'm sharing here a test case example that takes two matrices A and U of size M * NK, one matrix R of size NK * NK, and matrix W of size nM * NK with OOC enabled. You can run the application using this command:STARPU_LIMIT_CPU_MEM=109600
STARPU_GENERATE_TRACE=1 STARPU_STATS=1 STARPU_WORKER_STATS=1
STARPU_PROFILING=1 STARPU_DISK_SWAP=$SWAP_DIR STARPU_DISK_SWAP_BACKEND=unistd
STARPU_BUS_STATS=1 STARPU_SILENT=0 OMP_NUM_THREADS=1
MKL_NUM_THREADS=1 ./tb-modeling -i 1000 --freq=10 -m 250 -n 250 -k 250
I attach the code here. Please help.
Thanks,
Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
PhD Student
www.kaust.edu.sa
test_case_ooc.tar.gz
Description: application/gzip
- [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Amani Alonazi, 11/02/2019
- Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Amani Alonazi, 11/02/2019
- Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Samuel Thibault, 26/02/2019
