Archives de la liste
Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case
Chronologique Discussions
- To: starpu-devel@lists.gforge.inria.fr
- Cc: Hatem Ltaief <Hatem.Ltaief@kaust.edu.sa>
- Subject: Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case
- Date: Mon, 11 Feb 2019 13:23:19 +0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=amani.alonazi@kaust.edu.sa; spf=Pass smtp.mailfrom=amani.alonazi@kaust.edu.sa; spf=None smtp.helo=postmaster@mail-ed1-f52.google.com
- Ironport-phdr: 9a23:tukUJRRNdZil3H59eRwQnrIAGNpsv+yvbD5Q0YIujvd0So/mwa6yYByN2/xhgRfzUJnB7Loc0qyK6/CmATRIyK3CmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TW94jEIBxrwKxd+KPjrFY7OlcS30P2594HObwlSizexfbB/IA+qoQnNq8IbnZZsJqEtxxXTv3BGYf5WxWRmJVKSmxbz+MK994N9/ipTpvws6ddOXb31cKokQ7NYCi8mM30u683wqRbDVwqP6WACXWgQjxFFHhLK7BD+Xpf2ryv6qu9w0zSUMMHqUbw5Xymp4rx1QxH0ligIKz858HnWisNuiqJbvAmhrAF7z4LNfY2ZKOZycqbbcNgHR2ROQ9xRWjRODYOybYQBD+QPM+VFoYfju1QDtgGxCRW2Ce711jNEmn370Ksn2OohCwHG2wkgEsoSvXTRttr1MqYSWv2pwanMyjXDaelZ2Db86IPVdR0uu/SMUqh2ccrQ00UgDQfFjlKWqYP/PjKV1/8As2uB4Op9TuKvl3QrpB9srTiy3MsskZPGi5sTx1vZ+yt5x4M1Kse5SE59edOkE4FftzyBN4tqWM8tXXxnuDsgxr0do5G2ejUBxpc/xxPHdfCLb4yF7gjgWeuROzt0mm5pdbGlixuy70StzPD3WNOu31ZQtCVFl8HBtnAT2BzX7ciKUv598V2g2TaLzgzc9PxLLV0tmarVK5Mt3KQ8lpUUsUTEES/2nFv5gLWKeUUj/+ik8+XnYrP4qZ+AL4J4lB3yP6A0lsG8Aek0KBYCU3SY9Oim1LDv41X1QLBQgf03lqnZvoraJcMepqOhGQBV15ws6xC+Dzu8ytsYmX4HLFRfdxOGjojkIFLOL+rlDfekn1SgiilkyO3bPrH7GZXCNGDPkK39crZl905c1A0zwMhE55JIEL4BOurzWlLouNPFEBA5LRK7w+L8BdV514MeQn6PArSDPKPdv1+I4fgvI+aSa4MPuTb9LeIl5//0gnMjl18dZ/rh4ZxCc2yxBOx7ZkmUf3foqtMACnsR+AUwS/blhRuDVyRSbjC8RfES/DY+XaujBIHCDqmph7qIzibzSpRTb2ZHTFmIFnHhZYSsWP4Rcz7UL8N81CcNA+vyA7Q93A2j4Vepg4FsKfDZr2hB7cq6hYpFotbLnBR3zgRaSsGU0mWDVWZxxz9aRDYrx7w5rEBgjEyKg/Eh365oUOdL7vYMaT8UcIbGxrUmWdP7RxndONqFVRC9S4f+WGxjfpcK29YLJn1FNZCigxTEhXf4BrYUk/mGCMVx/P+GmXf2IMl5xjDN06xz11Q=
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
I tried it on V100+spinning desk/P100+SSDs/V100+SSDs. Unfortunately, it does freeze with large matrices.
t appears to be connected to three things:
1) [starpu][starpu_interface_end_driver_copy_async] Warning: the submission of asynchronous transfer from NUMA 0 to Disk 0 took a very long time (0.452278 ms)
For proper asynchronous transfer overlapping, data registered to StarPU must be allocated with starpu_malloc() or pinned with starpu_memory_pin()
2) Right after, the message about updating the perfmodel history:
[starpu][_starpu_update_perfmodel_history]
Too big deviation for model ssrc on cpu0_impl0 (Comb1): 44.715000 vs
average 15.980000, 1 such errors against 1 samples (+179.818523%),
flushing the performance model. Use the STARPU_HISTORY_MAX_ERROR
environement variable to control the threshold (currently 50%)
3) Out-of-core using dmda scheduler. Many thanks for your time.
A.
On Mon, Feb 11, 2019 at 11:56 AM Amani Alonazi <amani.alonazi@kaust.edu.sa> wrote:
Dear starpu-dev,A deadlock case (or extremely very very bad execution) is occurring from time to time. I'm sharing here a test case example that takes two matrices A and U of size M * NK, one matrix R of size NK * NK, and matrix W of size nM * NK with OOC enabled. You can run the application using this command:STARPU_LIMIT_CPU_MEM=109600 STARPU_GENERATE_TRACE=1 STARPU_STATS=1 STARPU_WORKER_STATS=1 STARPU_PROFILING=1 STARPU_DISK_SWAP=$SWAP_DIR STARPU_DISK_SWAP_BACKEND=unistd STARPU_BUS_STATS=1 STARPU_SILENT=0 OMP_NUM_THREADS=1 MKL_NUM_THREADS=1 ./tb-modeling -i 1000 --freq=10 -m 250 -n 250 -k 250I attach the code here. Please help.Thanks,Amani AlOnazi
PhD Student
Extreme Computing Research Center
King Abdullah University of Science and Technology
Al-Khawarizmi (Bldg.1)
Floor 0, Office 0203-WS02
Email: amani.alonazi@kaust.edu.sa
www.kaust.edu.sa
- [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Amani Alonazi, 11/02/2019
- Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Amani Alonazi, 11/02/2019
- Re: [Starpu-devel] execution time takes forever with cuda+large matrices+ooc test case, Samuel Thibault, 26/02/2019
