Archives de la liste
- To: Mirko Myllykoski <mirkom@cs.umu.se>
- Cc: Starpu Devel <starpu-devel@lists.gforge.inria.fr>
- Subject: Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory
- Date: Wed, 27 Feb 2019 14:10:36 -0800
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=samuel.thibault@inria.fr; spf=Neutral smtp.mailfrom=samuel.thibault@ens-lyon.org; spf=Pass smtp.helo=postmaster@hera.aquilenet.fr
- Ironport-phdr: 9a23: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
- List-archive: <http://lists.gforge.inria.fr/pipermail/starpu-devel/>
- Organization: I am not organized
Hello,
I hoped your issue could be related with Amani's, but apparently not.
Mirko Myllykoski, le sam. 23 févr. 2019 17:24:35 +0100, a ecrit:
> I waited until the code appeared to hang and captured a backtrace. I
> then repeated the capturing after letting the code to run additional
> 5-10 seconds. See the attachments.
It seems StarPU has a hard time evicting data indeed. Could you run the
starpu-memusage gdb macro? That'll give us an idea of how data are
busy enough that StarPU can't evict them.
Samuel
- [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Mirko Myllykoski, 23/02/2019
- Re: [Starpu-devel] StarPU code hangs when using a lot of GPU memory, Samuel Thibault, 27/02/2019
